Old 02-18-2009, 04:49 AM
gunlocators is on a distinguished road
Gecko 540 Mach 3 Keling Steppers on a Taig
Ok got everything setup tonight and having a issue. The steppers seemed to stutter when the taig is jogged.
it is semi smooth if mach 3 is set to 5lpi. Yet its is not smooth at all. This is the same with all 3 axis.
I have done all the Mach 3 optimizations for windows
I have removed the steppers from the taig and all axis turn smooth by hand
When steppers are jogged while removed from mill problem is the same so I ruled out gib binding.
Can anyone running this setup give a starting point for motor tuning maybe that will help get a reference where to start. Also I hooked this up to a xylotex stepper and it did the same so i doubt its a lot of bad steppers.
Setup
Taig Mill
Controller Gecko 540
PC Desktop Compac Presario Win XP Optimized for Mach 3
Steppers Keling 282oz KL23H276-30-8B
Power Supply Keling 48V
Old 02-18-2009, 12:13 PM
CoAMarcus's Avatar
CoAMarcus is on a distinguished road
What are your Mach3 settings? Also, are you using the XML file from our website?
Marcus Freimanis
Old 02-18-2009, 12:46 PM
Marcus
Steppers Wired Bipolar Parallel ----- 3.3k ohm resistors used in steppers
motor tuning this was last setting where it had least stutter in motors same in all 3 axis
steps per 40000
velocity 5
acceleration 2
step pulse 2
dir pulse 1
This is on a rev 4 controller Gecko just replaced. Never had a chance to use other rev controller due to motor cycle accident so its not like it worked now it does not this is a new setup
Old 02-20-2009, 08:53 AM
Gold Member
Mariss Freimanis is on a distinguished road
Mach3 "ports and pins": Set step "active high".
Mach3 "motor tuning": Set step pulse width to "2" microseconds.
In BIOS: Set parallel port to "EPP".
Mariss
Old 02-21-2009, 02:58 AM
Mariss Thank You For your help I PMed you
Keling servo as Taig spindle motor replacement? Hirudin Taig Mills & Lathes 35 08-18-2009 05:41 AM
4 Wire Keling Steppers Confusion n1bpd Automation Technology Products 6 09-05-2008 12:58 PM
Wiring keling steppers to FET 3 board..HELP Jackflash65 Automation Technology Products 1 04-13-2008 09:38 AM
Wiring Keling steppers to FET 3 board Jackflash65 Forum Questions or Problems 0 04-01-2008 11:58 AM
Keling Steppers Price Increase ??? Eurisko Automation Technology Products 4 02-20-2008 05:55 PM
