Hi everyone. I'm struggling a bit to get my motors running right. I'm running Mach 3, with a Gecko 540 and Kelling 48V power supply & motors on a Taig mill. I managed to calibrate everything fine, so each axis moves what it says it should when I ask it too. I tried some of the wizards in Mach 3 and they all seemed to work ok as long as the feed rate was high. My problems come when I tried to cut my first proper part. I generated the g code in meshcam and I was really conservative with the feed rates (didn't want to do any damage). It seems my motors just don't run at all if the feedrate is too low. By low I am talking about 4ipm (100mm/min). Surely I should be able to run the motors this slow? The part I test cut looks a mess. It's all of about the right dimensions but the circular pockets are all out of round, and the external walls are a bit chewed up where I'm guessing the mill has lost/gained steps. Any ideas why my motors stall at low speeds? Is this normal??? When I jog, if I set the reduced jog % too low then my motors don't move, but if I hold the shift key down they move fine. Thanks for any help guys! Rich |
| I've got this package: G540 4 axis package (one G540 + Three KL23H276-28-4B( 1/4” Dual shaft with a flat) 270 oz-in + one KL-350-48 48V/7.3A 115V /230V power supply). Trim, no I haven't tried that. What does it adjust? Thanks |
| ADJUST: This trimpot adjusts the motor for the smoothest possible low-speed operation. Set the motor speed to about 1/2 revolution per second and then turn the trimpot until a distinct null is noted in the motor’s vibration. This will result in the most even microstep placement for a given motor and power supply voltage. The default setting for this trimpot is at ½ -turn and the setting for your motor will be within +/- ¼-turn of the default setting. CR. |
| Rich, I asked you a question about your issues here in your other thread but I see you haven't replied. Please have a look and see if that may be your problem: http://cnczone.com/forums/showthread.php?t=73778 Dave
__________________ Dave->.. |
| Does the trim pot turn all the way around without wrecking? I was trimming my motors with the g540 and now I can't get one of my motors to spin when the speed is low like .5 rpm. I don't know where the original spot was on the pot now. I know so stupid of me. |
| Newbie- 5.25 floppy motor issues | KsiR | General Electronics Discussion | 3 | 05-10-2009 05:33 AM |
| X3 spindle speed issues | Legion99999 | Syil Products | 5 | 12-08-2008 04:42 AM |
| High speed issues, 2 Geckos, 1 car battery, 1 step up converter | poptarted | Gecko Drives | 13 | 07-31-2008 05:32 PM |
| More Motor Issues | pzzamakr1980 | Benchtop Machines | 1 | 10-19-2007 04:35 AM |
| speed issues | sixpence | DIY-CNC Router Table Machines | 10 | 09-18-2004 08:28 PM |
