Old 12-16-2004, 01:36 AM
Grom1 is on a distinguished road
Power Supply for Geckodrive
I have a Nema 34 size of motor.It has a 6 amp per phase curent of consumption.White paper tells that a power supply must hase the 2/3 rated curent of motor i.e. 4 amp.But in microstepping mode is two windings of motor to connect to the power supply at the same time i.e. power supply must hase 12 amp of load current.What does power supply uses in may application in this case?
Old 12-16-2004, 07:12 AM
ger21's Avatar
The 4a per motor is all you will need.
Old 12-16-2004, 10:49 AM
ViperTX is on a distinguished road
So, you'll use max. current when you are stepping at max. speed and when you are holding a position (hmmmmm.....I should look at some stepper charts). Anyway if you have a larger supply then required it certainly won't hurt.
Old 12-16-2004, 12:16 PM
ger21's Avatar
Quoted from the White Papers at Geckodrive.com:
"The easiest factor in choosing a power supply is its current rating. The current rating of the supply is based on your motor choice. The drive will always draw less than 2/3 of the motor’s rated current when it is parallel (or half-winding) connected and 1/3 of the motor’s rated current when it is series (or full-winding) connected. That is to say, a 6 Amp / phase motor will require a 4 Amp rated supply when parallel connected and a 2 Amp rated supply when series connected. If multiple motors and drives are used, add the current requirements of each to arrive at the total power supply current rating."
This information specifically applies to Geckos. Other types of drives may or may not follow the above rules.
Old 12-27-2004, 08:50 PM
plateroomred is on a distinguished road
Hello,
Where can I get the components to build a 72v@25 amps power supply from either 120 or 240 ac, to power my three servo's from my 320 gecko's?
Thanks,
Larry
P.S. I believe I have posted this in the wrong area, any help would be greatly appreciated.
Old 12-28-2004, 12:10 AM
Originally Posted by plateroomred
Hello,
Thanks,
Larry
Ebay...look for toroids that have a secondary rating of 50 volts....why 72 VDC....what's the rating of the servo?
Old 12-28-2004, 08:35 AM
Gold Member
CJL5585 is on a distinguished road
Don't forget that the output voltage of a DC supply (after being rectified and filtered) will be 1.414 times the transformer output voltage (AC).
A transformer with a 72 Volt AC output will give a DC output of approximately 101.80 Volts DC. A transformer with an output of 50 VAC will have a voltage of 70.7 Volts DC after the rectifiers and filter capacitor(s).
Old 12-31-2004, 06:19 PM
Don C is on a distinguished road
Smile power supply
Go to http://www.toroid.com
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 10:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 04:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 10:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 11:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 11:36 PM
