Old 02-15-2009, 09:17 PM
WayneC is on a distinguished road
Did I fry my Gecko 202?
I have been having an intermittent problem with one coil not working on my Xdrive motor. I thought I found it a couple of times now with loose wires or plugs, but each time I think I have it fixed it comes back to bite me.
This last time it ran for 20 minutes on an sign job (just a test thankfully) before the gantry racked as one of the X axis motors would not change directions. No permanent damage, but I can't get any work done with the damn thing doing this.
After runnning the normal reset and software checks, I again isolated the problem to the drivers, not the motors. I traced it to the same Gecko 202 driver that was the problem before.
While the controller was operating, I poked the connectors at the Gecko with a wooden dowel. When I poked the coil connector I saw a tiny arc, and the motor quite changing direction. When I poked it again, the same small spark, and the motor began working againg. I poked it again, and this time got a larger spark and the lights on the Gecko went out and the motor quite working at all. I did not find a blown fuse in the controller, but the Gecko would not reset either.
I ordered two new G202s so I'll have a spare. But what I'm wanting to know is- did I fry the Gecko? And is this sort of sparking normal? Did I FIND an intermittent connection, or did I CAUSE an intermittent problem
Are G202s known for connection problems? Can I do anything to make this less of a problem . Maybe not poke them with dowels?
Argghh.
Thanks for any input
Wayne C
Old 02-15-2009, 10:30 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Gecko will repair your 202 driver--Most likely for free when it's the first time--if you send it to them.
CR.
Newbie- Which Gecko should I use? Ostni Gecko Drives 3 11-19-2008 06:59 PM
Gecko 320 Ed Williams Gecko Drives 1 05-17-2006 08:17 PM
Gecko 210 Help... Gads Gecko Drives 4 03-23-2006 11:36 AM
Gecko 340 v msa 12-80 mmjpotter Servo Motors and Drives 1 12-07-2005 07:36 PM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 08:42 PM
