Old 02-10-2009, 09:55 PM
don_don is on a distinguished road
g540 setup question
I have just purchased the G540 4 axis package from Keling and not sure what size resisters I should be using. I have read the user manual and through the forums here and still not confident I understand.
G540 4 axis package (One G540 + Four
KL23H284-35-4B (1/4” Dual shaft with a flat) 387 oz-in + one KL-600-
48 48V/12.5A 115V /230Vpower supply)
http://www.kelinginc.net/KL23H284-35-4B.pdf (motor spec sheet)
also what is a good online electronics store to purchase these from and also limit switches / home switches / e-stop
Old 02-11-2009, 09:30 AM
Richards is on a distinguished road
The KL23H284-35-4B stepper motor is rated at 3.5A, so, with the G540, you would use a 3.5K resistor (1/8W to 1/2W). Radio Shack has 3.3K 1/4W resistors, which would work to get you started.
www.automationdirect.com sells switches, proximity sensors, contactors, relays, etc. www.jameco.com and www.digikey.com sell electronic parts, such as resistors, chips, etc.
Old 02-11-2009, 09:55 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Digikey has a 3.48K 1/4 Watt resistor that is perfect. Ten cents.
http://dkc1.digikey.com/us/en/pdf/Current.html
http://search.digikey.com/scripts/Dk...sistor&stock=1
CR.
Old 02-13-2009, 10:29 PM
Thanks for the help. I ordered the resisters/limit switches/home switches on wednesday.
recieved my G540 4 axis kit from Keling yesturday and . Today was the first day I brought my machine home after 3 yrs working on it (very exciting). This is my first cnc so still trying to figure out what to do tomorrow.
Name:	assembled (Medium).jpg‎
Old 02-13-2009, 10:38 PM
That's a nice looking machine don! Good work! I bet you can't wait to make some sawdust.
CR.
Old 02-14-2009, 06:37 PM
fretsman's Avatar
fretsman is on a distinguished road
Don, just wanted to comment on your tank of a machine there. Looks built VERY well and would love to see more pics of it if you have them-
What are your travels?
Thanks,
Dave
Dave->..
Old 02-15-2009, 12:57 AM
table is about 32 by 15. I will post more pics here as I complete project. Received my resisters from digikey today but was unable to find 22/4 shielded wire or I would have started to connect controller/motors.
Old 02-15-2009, 09:18 AM
You will also need some other stuff:
You can use THIS wire for motor cables and home/limit switches. Ground the drain wire ONLY at the driver end.
http://cgi.ebay.com/Servo-Motor-Wire...3286.m20.l1116
You won't need any db9 motor connectors with the G540, as they come WITH it. The G540 also has circuitry for simple spindle speed control and outputs for dc relays to turn coolant pump on or off.
These inexpensive relays are very good :
http://www.surpluscenter.com/item.as...tname=electric
You will also need an estop switch. This one from Keling only costs 10 bucks and works fine:
http://kelinginc.net/CNCPackage.html
On that same page Is a DB25 serial connector which you may need.
The G540 is so small that many are mounting theirs INSIDE the computer case.
Camtronics has a case MADE for the G540:
http://s120220635.onlinehome.us/stepper-components.asp
CR.
Old 02-15-2009, 10:48 AM
LaserImage is on a distinguished road
It would seem to me that Keling would be providing great customer service if they provided the resistors with their "package". They don't cost much and if they provided them to their customers, it would save a lot of time and trouble trying to figure out what is needed and where to get it...
Gary
Old 02-15-2009, 07:10 PM
autocadplease is on a distinguished road
I just bought the same package too. Do you really need shielded wire?
"Radio Shack has 3.3K 1/4W resistors, which would work to get you started."
When so say get you started, can they be used permanently? Or does the 0.2K make a difference?
  #11   Ban this user!
Old 02-15-2009, 07:19 PM
Shielded wire is BEST, but optional on motor cables. Shielded wire is NECESSARY for home/limit switches.
There is a slight loss of performance when you limit the Amperage. I prefer to wait and get the proper resistor size, just because I KNOW that once I solder those in and mount the connectors--I'm NOT going to unsolder and replace them.
So, at least for ME, it's permanent.
CR.
  #12   Ban this user!
I didn't use it and I have not having any problems at all. Not to say you won't, or it that it is a good idea, just that mine seems fine.
3.3K vs 3.5K will reduce the amount of current you have going to the motors - by about 6%. Figure out what a 6% reduction in speed will be and decide if you need that extra bit - probably not. So, yes it will make a difference but how important is it?
Gary
Gecko G540 Quick question mad_dog096 DIY-CNC Router Table Machines 0 01-02-2009 09:06 PM
G540 resistor question LaserImage Gecko Drives 2 12-01-2008 11:54 AM
Setup Question tikka308 General Metal Working Machines 8 07-09-2007 10:45 AM
Setup question obscurity PicStep Controllers 5 01-14-2007 02:05 PM
Another Setup Question... rcazwillis TurboCNC 4 07-04-2005 09:55 AM
