Old 02-10-2009, 11:30 AM
rbcmetalwork is on a distinguished road
G320 encoder power supply
I have a three axis system with G320s and I am unclear on the wiring of a separate 5VDC power supply for the encoders (if they draw more than 50mA).
For any given G320:
Are three things attached to terminal 6 of the G320? The wire from the encoder negative, the wire from the 5VDC power supply ground and one end of the 470 ohm resistor?
Are three things attached to terminal 7 of the G320? The wire from the encoder positive, the wire from the 5VDC power supply positive and the other end of the 470 ohm resistor?
Can a single 5VDC power supply, with adequate current, be used for powering all three encoders (One output going to three places)?
What wattage should the 470 ohm resistor be?
Randy
Honolulu, Hawaii
Old 02-10-2009, 12:36 PM
H.O H.O is offline
H.O is on a distinguished road
I don't have any G320's so I hope I'm not too far off here but here's how I see it.
Originally Posted by rbcmetalwork View Post
For any given G320:
Yes, that is correct. The resistor is there to "fool" the drive thinking it is supplying current to an encoder. I believe it's needed for the internal voltage regulator to work properly. The ground for the encoder and ground from the powersupply gives the encoder and G320 a common reference for the A and B signals.
NO. Only the other end of the 470 ohm resistor. This terminal is the +5V "output" so you shouldn't connect the external +5V powersupply to it. Connect the external +5V to your encoders positive wire only.
Yes, that shouldn't be any problem. Wire the +5V from you external powersupply to the postive lead of all three encoders but not to any connection on any of the drives.
Since the voltage across the 470ohm resistor is 5V the current thru it is ~11mA so the power is developed in it is ~0.05W. A 1/4W or 1/8W resistor is more than enough.
HTH
/Henrik.
Old 02-10-2009, 09:41 PM
Adamj12b is on a distinguished road
I have a setup like this on my knee mill. I talked to Mariss when I was setting up my system. He told me that I needed a separate supply for each drive. IDK why, but thats what I did. Also, I have to look into this tomorrow, but I only have one common ground for the logic, I believe. I cant remember exactly right now though.
-Adam
www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
DC speed control as power supply for g320? DennisCNC Gecko Drives 5 02-19-2008 11:43 AM
UNKNOWN ENCODER & G320. salman Gecko Drives 0 01-02-2008 10:45 AM
encoder question for G320 CNC Darren Gecko Drives 7 11-15-2007 12:14 PM
Transformer for power supply for G100/G320 jamma General Electronics Discussion 3 09-22-2006 02:13 AM
encoder question for use on G320 Runner4404spd Gecko Drives 0 12-08-2005 10:32 PM
