Old 02-07-2009, 02:34 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Rev 4 Gecko 540; not coming out of fault?
Hey there,
I sent my previous Gecko 540 for evaluation, I got an invoice back stating that all G250's boards passed. It did however say in the invoice that my BOB was updated to the latest one.
I wired up the 540 as normal and it did not come out of fault. Nothing was changed with EMC2 or any programs.
Then i said "Must be the internal switch on the BOB", Opened up the new 540 I got today and there was no switch.... So then I said, maybe I'll invert pin 16 in EMC2 as charge pump (I inverted and univerted the pin). Gecko did not come out of fault.
I have my E-stop wired just like before, like I said. Nothing has changed, wiring is the same, programs and pins are the same.
I also didn't see anything etched on the BOB, do the new ones say Rev 4 or something? I thought mu old ones did.
-Jason
Old 02-07-2009, 02:50 PM
ihavenofish is on a distinguished road
Originally Posted by SpeedsCustom View Post
Hey there,
-Jason
mine is rev4 and has the little switch inside - you need to pull the bob off the drives though to get access if i recall.
i vaguely remember reading that rev5 will have the switch moved to another location. perhaps you need to go searching
Old 02-07-2009, 02:54 PM
I never took off the entire BOB. Duh! Ok ok, should be under.
-Jason
Gecko 6320 Fault Issue. Rich05 Gecko Drives 0 12-22-2007 09:03 PM
Gecko Fault Circuit bgolash Gecko Drives 3 10-01-2006 09:51 PM
Gecko 202 Light not coming on scheek Gecko Drives 3 09-05-2006 01:49 PM
Is gecko coming out with a CNCadmin Gecko Drives 3 03-03-2005 08:36 PM
Help! Consistent Gecko Fault or Servo Stall Noah Gecko Drives 11 06-30-2004 10:48 AM
