in my folly ive constructed a power supply using a torroidial transformer rated for 45v. turning it on ive found 66v at the capacitor. is this too much for my g540 with a max voltage of 50v. and if, as it probably is, too much. can any one help with maybe a regulator circuit, as the torroidial put a hole in my wallet. |
| DO NOT use this PS with the 50V MAX G450. Overvoltage is one of the few ways to kill it. Save it for a future machine or sell it on ebay. THIS $60 PSU will run most Nema 23 stepper motors with G540: KL-350-48 48V/7.3A http://kelinginc.net/SwitchingPowerSupply.html CR. |
| A transformer with 45VAC secondard will make: 45 * 1.414 - 1.4 = 62 volts at the filter cap assuming nominal line voltage. Most transformers will make more voltage no load which is why you are seeing 66. Putting 66 volts on the G540 is the kiss of death. Personally I subscribe to the keep it simple approach and an unregulated supply is simple and adequate for driving steppers. I am using a Antek 48V 500 watt power supply with my G540. I chose 500 watts because (3.5x4) * 2/3 is 9.2 amps which is very close to 500 watts. It looks like they now only sell 47V 500 watt supply. http://www.antekinc.com/ps.html If you really want to make your own power supply you can buy nice transformers here too. I recommend a 34 or 35 volt secondard. I believe the 47volt PS uses a 34 volt secondary and the 48 volt PS uses a 35 volt secondary. I am using keling tech KL23H276-28-4B motors and they work very well with the G540. I have the machine configured for 60IPM rapids. I can make them move 120 but I didn't test to see if they were loosing steps at that rate. |
| There has been many post here in the past on doing this, and it is much more efficient than external regulation circuitry. Al.
#11
| If you carefully remove the outer insulation wrapping, this will expose the secondary wire winding, these are the wire turns referred to. You just unwind the amount of turns that you need to reduce the secondary voltage by. Reattach or solder the secondary flying lead conductor and rewind on the insulation tape previously removed. It is a relatively simple procedure and cost virtually nothing except time. If you want to find out the how many turns/volt the transformer has, you can wind on 5 or 10 turns of small gauge wire on top of the present taped winding, power up the transformer and measure the AC on this new winding, this will give you the ratio of turns per volt. Al.
#12
| Steve |
| G540 Spindle speed output voltage problem | georgef8 | Gecko Drives | 5 | 09-22-2009 10:18 AM |
| g540 | Scooby Doo | Gecko Drives | 62 | 05-17-2009 01:44 PM |
| G540 - WOW! | LaserImage | Gecko Drives | 6 | 12-04-2008 03:30 PM |
| G540 Low voltage for E-stop and limits? | MrWild | Gecko Drives | 4 | 10-14-2008 04:28 AM |
| Help..Stuck at relay ext dc voltage missing but dc voltage OK ? | Dirky | Bridgeport and Hardinge Mills | 24 | 11-27-2007 07:33 AM |
