Old 01-24-2009, 07:56 PM
suzukirmz is on a distinguished road
old motors new drive?
HI
A friend of mine has an old CNC plasma cutting machine is a micatronic 2500,
On the motors it says SEM MADE IN LONDON.. i think the year is 1989?
I talk to a person from micatornic and he say that they later exchange that motor drive whit bruny14
The software and the motors drive is very old
Now I am thinking is it possible to get a gecko drive to work whit them motors
And use mach3 software
Thanks laurits
Old 01-24-2009, 08:19 PM
NC Cams is on a distinguished road
Check the specs on the motors at the SEM webside. USe the maode and S/N.
Once you kown the specs (amps, volta) you can sthen "size" the servo amps as needed.
YOu ight even find the specs on the motor ID taks.
Whne you work on old legacy equipment, one somtimes has to do a lot of legork and/or goo scraping to properly identify motors for interfacing with newer equipment.
TH factory servcie place for SEM is Clarkson in USA. I d'not know who does service in Europe. If you call and ask SEMm be prepared with more info than you presented here. MOdel number and S/N MINIMUM should be on a motor tag. My SEM's have amps and volt ratings also which is he essence of your question..
Old 02-05-2009, 10:20 AM
thank you for yore reply
today i was able to take some pictures of the motors.. meaby you can see if is possible at all... ther are only to identical motors on system...
any reply would be appreciated.
the pictures are of the same motor..
thanks laurits
ID:	75116   Click image for larger version
Drive for low inductance motors? pixpop Servo Motors and Drives 3 07-17-2007 02:40 AM
2 drive motors for 1 axis WI_HUNTER_DAN DIY-CNC Router Table Machines 3 01-29-2007 09:02 PM
Can G202's drive these motors ?? richyrich212t Gecko Drives 3 03-25-2006 08:35 PM
can brushless drive drive brushed motors ? max_imum2000 Servo Motors and Drives 2 02-09-2006 07:35 AM
2 motors 1 drive Fozzy Gecko Drives 0 04-04-2005 12:18 PM
