Old 12-03-2004, 05:06 AM
beausdn is on a distinguished road
dc drive as psu
Hi i was going to use a minarik dc drive (set the E max to 40vdc, 18A ) as my power supply but was told that was not compatable with the gecko 320's and i was wondering why i had planned on using a cap on the output to flatten out the ripple and even using a bridge to block the cemf. since it would be pretty much flat line dc i dont understand why it wont be suitable i am not second guessing what i was told i am just interested in knowing why it wont work i also had some dc digital ammeters lying around and installed them , but they screwed things up so i had to remove them from the cct thought it would be cool to see guess the drives dont like the shunts anyway once i removed the meters all went well tried one of the sample programs that comes with turbocnc and watched the motor spin neat to finally see some action all i have to do now is build the mahine itself like that will be easier said then done
Driving a 4 pole ac servo with a 6 pole drive TommyB Servo Motors and Drives 4 04-28-2005 02:17 PM
Using a large drive on small motor? murphy625 General Electronics Discussion 0 03-11-2005 05:23 PM
Help! ...no drive movement CRFultz General Electronics Discussion 4 01-21-2005 08:30 PM
Good DC motor and drive JRoque General Electronics Discussion 11 01-02-2005 10:38 PM
Belts versus Direct Drive bsmith DIY-CNC Router Table Machines 12 06-06-2004 11:09 PM
