Old 01-24-2009, 12:07 PM
Wanna be
Hack is on a distinguished road
Wiring a G203V
I am working on a new cnc mill. It is a RF31 Clone that I bought from wholesale tool a few years ago, but the new part is the CNC. Due to the cold in the shop this time of year I am taking some indoor time and wiring up a new controller this weekend in my home office. Sure beats the 14 degrees outside.
I am using 3 G203V's, a CNC4PC breakoutboard (the C10), and a 48 watt power suppply from Keling. I am also using an independent 5V supply that I got from MPJA.
On the geckos I have:
Pins 1 and 2 of the geckos to the 48 volts of the power supply,
Pins 3- 6 to the stepper motors
Pin 7 is empty
Pin 8 & 9 to the breakout board for step and direction. These are wired to pins 2&3 for x, 3&4 for y, and 5&6 for z.
What do I do with pin 10 (common)? I am almost positive that this should be a +5v supply. Is this correct? If so, should I get this from the +5V coming off the 5 v power supply or can I also get it from common connections on the BOB?
Pins 11 and 12 I have open as my motors are rated at 7 amps
Please double check my thinking and verify that I have all pins correct. Also let me know if I am correct in my thinking for pin 10 of the gecko.
Thanks all.
Dan
Check out what I am working on at www.routerbitz.com!
Old 01-24-2009, 12:50 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Dan. It all sounds good, except:
Gecko 201s need a +5V. The G203Vs (Or the G540) want a GROUND on COM. Set your COM jumper on the C10 to jumper pins 1 and 2. Then attach the 203V pin 10 to any COM terminal on the C10.
Step and direction should be wired to pins 2 & 3 for X, 4 & 5 for Y, and 6 & 7 for Z.
If you are using three 7A motors, your power supply must provide at least 13A. What stepper motors are you using?
Terminal # 1 is the Power ground, and # 2 is Positive. Make sure you don't reverse these, or allow any strands of wire to short between--Or you could KILL the unkillable 203V.
CR.
Old 01-24-2009, 01:49 PM
I just remembered something that I meant to say in previous post:
Are you attaching the G203s to a heat sink?
G203Vs require a heat sink to operate on more than 3A.
CR.
Old 01-24-2009, 01:55 PM
Wanna be
Easy enough to do
That is easy enough. Can anyone confirm this just to be sure?
Thanks for the note about the heatsink. I had not itended to do this, but I will make provisions for this before I am done.
Dan
Old 01-24-2009, 02:01 PM
Torchhead is on a distinguished road
Confirmed as to the polarity of G203V COM (ref to PCGND). Also the drive signals to the Step (from your BOB) have to be Active Step HIGH (Red X in MACH).
TOM CAUDLE
www.CandCNC.com
Totally Modular CNC Electronics
Old 01-25-2009, 01:21 AM
phungi is on a distinguished road
I run almost the same spec, 42v 7amps c11g.
Confirming Heatsinks and decent airflow are needed at 7amps.
Wiring advice is correct also.
Old 04-01-2009, 12:25 PM
carlosescuela is on a distinguished road
CR.
hi, i am using a CNC4PC breakoutboard (the C10) too, but i have two (2) g201 and one (1) g203v! i have wired the term.10 of the g201 to the common pin of the c10. how can i do with the 203v? thanks a lot!
G203V help !!!!!!! native34 Gecko Drives 6 09-15-2009 12:23 PM
g203v help eloid DIY-CNC Router Table Machines 1 08-18-2008 07:59 PM
G203V Steps? Big John T Gecko Drives 4 10-05-2007 10:09 AM
G203V wiring dneisler Gecko Drives 4 07-13-2007 01:10 AM
G203V question Eson Gecko Drives 2 03-04-2007 02:56 PM
