Old 01-20-2009, 05:57 PM
TommieK is on a distinguished road
Power Supply
Hello all:
It was recommended to me to get the G540 and a 48-50 volt power supply. I've ordered the G540, Now, from whom do I order the Power supply (resisters and all later). Thanks all Tom
Old 01-20-2009, 10:30 PM
irving2008 is on a distinguished road
Originally Posted by TommieK View Post
Hello all:
Keling, or some good ones on eBay
Old 01-21-2009, 05:51 PM
Power Supply
Thank you Irving. Looks like a lot of nice choices. I have done a DIY of the JGRO and I expect that it will want to grow a little (Lead screws and such). Any advice on Voltage and Amperage, as I really need a starting place. Thank you all. Tom
Old 01-21-2009, 10:44 PM
If you have the G540 then 48v supply is the way to go for longer term capability, there's little point in going for a lower voltage. Your voltage must not exceed the voltage rating of the driver (the stepper motor voltage rating is irrelevant).
Current capacity depends on your stepper motors. Either size for the motors you have now or size for the maximum drive capacity of the G540 if you expect to increase the motor size later.
Power supplies are relatively cheap (48v 8.8A is $65-odd). You need a current capacity of typically 70% of 3x stepper phase current (4x for 4 axis). It doesn't matter if you have more capacity as the driver/motor will only take what it needs but there's no point in spending more than sensible. The G540 is 4-axis 3.5A so you will never need more than 10A from the supply if it is fully loaded on all 4 axis.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
What power supply erkiwi General Electronics Discussion 0 09-02-2007 03:17 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
power supply asd General Electronics Discussion 2 07-10-2004 04:53 PM
