Old 01-10-2009, 03:12 AM
chester88 is on a distinguished road
Gecko timing
I'm looking for the timing specs for the gecko 320. The manual does not specify the timing of direction hold time or direction setup time.
Here is the list on the EMC wiki of gecko products.
goes step hold, step space, direction hold, direction setup time .
If I get solid answers I will add them to the wiki and stepconf program.
Gecko 201 500 4000 20000 1000
Gecko 202 500 4500 20000 1000
Gecko 203v 2000 1000 200 200
Gecko 210 500 4000 20000 1000
Gecko 212 500 4000 20000 1000
Gecko 320 500 3500 ? ?
Old 01-10-2009, 09:04 PM
Gold Member
Mariss Freimanis is on a distinguished road
The DIR setup and hold times are less than 200nS. The STP and DIR signal paths are symmetrical; they pass through identical optoisolator channel circuits. The STP signal winds up on the CLK input of an Up/Down counter while the DIR signal winds up on the counter's U/D input. The active edge is the rising STP edge so change DIR on the falling edge.
That takes care of setup and hold. STP pulse min logic '0' and '1' times are constrained by the opto characteristics, primarily the opto storage delay time. Min logic '0' time is 500nS, min logic '1' time is 3.5uS.
The input DC levels are <0.5V and >4.5V. Rise and fall times should be 100nS or less. The opto LEDs are connected common anode to +5VDC so the preferred STP polarity is logic '1' when there is no activity on the STP input (narrow logic '0' pulses).
Hope that helps.
Mariss
Old 01-10-2009, 09:33 PM
Thank you I will add the timing spec to the EMC wiki.
i want to cut timing pulleys , so help !! max_imum2000 General Metalwork Discussion 18 08-08-2008 12:16 PM
THC Timing? Red Earth CNC Plasma and Waterjet Machines 27 04-16-2007 10:03 AM
Timing Belts .200 xl elogicca DIY-CNC Router Table Machines 1 11-13-2006 08:09 PM
Timing Pulleys h_2_o Benchtop Machines 7 02-02-2005 10:26 PM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 08:42 PM
