Results 1 to 3 of 3
Thread: Step frequency
    drk
    drk is offline
    Oct 2004
    india
    Step frequency
    Hi, I recently changed my motors from steppers( i ran them with my self made L297, L298 driver) to some old iron core type electrocraft motors ( 60V, 16ozin) and used Gecko 340 s for that.
    The encoder are renco with 500 lines ( 2000ppr after quadrature). The machine im retrofitting with these motors has a 22mm ballscrew with 5TPI.
    My question to you experts is that :
    1.To achieve a linear travel speed of 100-400 inches a minute, what should be my step signal grequency range.
    2. With geck drives, there is no nee for tacho feedback, so while the drive makes sure that the difference between the no of pulses sent ( step signal) and those received from the encoder are the same ( position reached) what parameter controls the time the motor takes to reach the desired position and the motor speed at which it shall rotoate, is it the voltage??
    Mar 2003
    Shelby Twp, MI....USA
    It depends on what you set the step multiplier to. If set to 1, you need 400 inches divided by 60seconds, times 5 tpi, times 2000 steps per turn, which is 66,666 Khz. Set the multiplier to 2 and you'd only need half that. I think this is right.
    No, not the voltage. The software controller (Mach2, for example) has settings for acceleration, and sends that information to the Gecko's based on the programmed feed rates and distances moved.
    drk
    drk is offline
    Oct 2004
    india
    Thanks, I just hope my microcontroller is able to generate a good enough waveform at that high a freq.
  1. Chatter
    By gabeless in forum Hard and High Speed Machining
    Last Post: 07-14-2005, 12:09 PM
  2. Ametek motors and step down ratio
    By dowling177 in forum Servo Motors and Drives
    Last Post: 03-01-2005, 01:24 PM
  3. step angle question??
    By kywoodwrkr in forum DIY CNC Router Table Machines
    Last Post: 02-22-2005, 11:04 AM
  4. Dirction / Step lines!
    By bigal in forum TurboCNC
    Last Post: 02-06-2005, 02:51 PM
  5. Choosing a step rate?
    By Rhodan in forum General Electronics Discussion
    Last Post: 04-26-2004, 10:42 AM
