Old 12-17-2008, 10:55 PM
hpghost is on a distinguished road
power supply required for 4 axis system
hi,
I am willing to go for a gecko G201 4 axis system (X axis with 2 steppers).
I would like your advise on 3 things:
1 - can I use 2 power supplies (one for 2 motors)
2 - if I use only one supply which capacity it shall have knowing that I want to achieve high torque at high speed because my machine gantry is heavy (30-40kg). I beleive I will use steppers parallel connected.
3- Am I missing something to run the system?
here are the details of what I may intent to use:
- steppers:
860 oz. in.motor for Z axis
then for X and Y, 3 steppers: No. of wires=4, Bipolar Volts= 3.0, Amps=6.0, Ohms=0.5, Holding torque=8.5Nm. 0r 1200 oz-in
- breackout board:
CNC4PC C1G parallel port interface
- 4pcs G201 drives
- Power supply:
big question...
http://cgi.ebay.com/48V-11A-400W-Pow...742.m153.l1262
see my questions above...
if you'd like to see my machine (currently running on Xylotex):
http://www.raptor-rc.com/cnc.htm
thanking you in advance for your advises.
Old 12-18-2008, 10:21 AM
ger21's Avatar
About 16-20 amps, and for voltage, use 32 x sq rt of the motors inductance.
Old 12-18-2008, 10:34 AM
Lightbulb supply?
so I beleive that I need only one power supply as shown on the web link. is it?
Unipolar Motors, Power Supply, and 3 Axis Controller Nightwork Stepper Motors and Drives 1 12-06-2007 06:04 PM
Help w/ power supply for a 3-axis servo system yantra3d General Electronics Discussion 2 07-25-2007 02:41 PM
Compressed air supply required for 50A plasma.. hotponyshoes CNC Plasma and Waterjet Machines 13 04-15-2007 08:16 AM
4-axis and Contorler questions and power supply wakeboard DIY-CNC Router Table Machines 15 01-13-2004 05:40 PM
Any recommendations for a power supply for their 3 axis board? ljoe1969 Xylotex 8 11-05-2003 03:39 PM
