Hi all, hope everyone is doing well!! On another forum there is some discussion concerning Estops It has been said that a Estop should stop all movement as quickly and safely as possible. If we do not use the inputs on the computer to preform a Estop then removing power from drives etc seems to be the next order of events to ensure the machine comes to a safe and immediate stop. My question is; Is it ok to turn off the DC power to the steppers on Gecko 201 drives?? Any suggestion, comments are welcome. olf20 |
| No, never switch the DC power, it can kill the drive. I think switching it back on is worse than switching it off, but not entirely sure.
| Thanks for the reply Gerry. I was pretty sure that you could not disconnect the power to the gecko drives / motors. What does the industry do to ensure a quick and immediate stop without removing power? olf20 |
| Servos with brakes.
| I did query this with Mr Gecko when using fuses in the motor feeds - he said its ok ! ! ! Can't see the difference - both cut DC but one good, one bad? |
| As far as I could understand, cutting power is ok, but connecting power on the DC side is bad. So if you have the E-stop breaker on the DC side, you will have to switch off the AC side before resetting the E-stop. Sounds messy to me. As far as I know, most gecko drivers have a disable function. Why not use this one? I believe it will cut all power to the motors, and it's safe to use. Check the manual for confirmation. |
| You're forgetting the diode in the fused set up. When a fuse blows and there is innertia in the machine, it will produce power. Without a diode allowing the power to bleed back into the system, drive damage can happen. Something that I had to get my head around with stepper systems is that stopping the step pulses, stops the motor. Period. No step pulses, no motion. Servos on the other hand can keep traveling with power stored in caps. Confusing aspects of the two can have you adding unneeded complexity. Cutting power to the AC side won't stop a stepper that is getting pulses until the cap drains. Chopping DC will blow the drives without the diode to drain off the generated voltage as the motor stops spinning. Stop the pulses, and the drive stops turning the motor. BOBs with charge pumps on them will stop sending step pulses to the drives when the 15mhz signal s lost. They also have E stop circuits that stop step signals when the e-stop is hit. |
| I also believe Mariss has made some tests to see what happens when you cut power on the DC side. As far as I can remember, he recorded som pretty high voltage spikes, but nothing that killed the driver (Stepper motor). The fuse is also placed after the capacitors, so once the fuse blows, there is no power to the motors. The table/head might keep on moving if there is not enough resistance to stop it from moving, but on most machines this wont even be a problem. I know the PMDX-122 has a e-stop feature built in. It disables all signals to the data bus once the e-stop button has been pressed. This is a feature you can disable if you want to. If you really want to cut power to the motors, you should take a look at the disable function. |
#10
2. Several BOBs have the e-stop built in, its why all the talk of cutting mains power, or DC supply (for a stepper system) is way over kill |
#11
| 1. Never heard about putting a diode over the fuse, but it does make sense. I'm using G201's and I have a fuse on the DC side. And as far as I understand, when the fuse blows, the driver is already dead. A fuse is simply just to slow. And I believe your right about the G540 being able to handle cutting the power on the DC side. I just thought the G201 could take it too. 2. Never said that it wasn't. Just pointed out that the disable function is a good way to cut power to the motors if he wants to. After all, if there is a fault in the electrical wiring in the machine (cutting wires or something), disabling power to the motors might be a good idea. Overkill maybe, but it's good to be on the safe side. I don't have this on my machines. I disable the signals only. Just to make sure I get it right. The charge pump circuit/signal is something comming from the computer right? The PMDX-122 can handle e-stop signals on board. It doesn't have to wait for the computer to register the e-stop before disabling the outputs. Is this the way everyone is doing it? |
#12
| Bob |
| Gecko Drives | Smackre | Gecko Drives | 8 | 09-11-2011 08:12 PM |
| gecko drives | eloid | Gecko Drives | 2 | 02-19-2007 08:42 PM |
| Gecko 202 drives | Pete Stenabaugh | Gecko Drives | 16 | 07-29-2006 07:39 PM |
| About the Gecko Drives... | A2Nl301 | Gecko Drives | 5 | 02-08-2006 11:26 PM |
| Gecko Drives | ninewgt | Gecko Drives | 8 | 06-23-2003 08:12 PM |
