Old 12-06-2008, 09:50 PM
Wolfesmetalfab is on a distinguished road
What are you using for Heatsinks for G200 drives
I have 3 G203 drives, and was wondering what everyone else is using for heatsinks. actual heatsinks, or just aluminum plate. [sorry my shift key is acting up lol] i see they measure only 2.5 by 2.5 inches, so either 1 good sized heatsink, or 3 seperate ones. also what are you doing for fans, 1, none, or what.
Socket A cpu heatsink
something like this work well even though it is 1/4 inch smaller than the drive. do you think i should run 3 of these with the fans all wired up.
brian
Old 12-10-2008, 06:30 AM
blackbeard52 is on a distinguished road
I use the heatsinks in old blown PC power supplies. but cpu sinks will work better. you dont need a fan on each one but one blowing across all mounted in the case.
B
Old 12-10-2008, 12:21 PM
Thanks Blackbeard, Ive got an old cpu heatsink or two laying around, Ill try them and then get another one if I dont have enough. I was trying to find a larger heatsink to hold them all, and was having trouble finding one.
Old 12-10-2008, 12:43 PM
Bubba's Avatar
Bubba is on a distinguished road
I made one out of a piece of 1/2 x 2 3/4" of 6061 by cutting some "fins" on the back side and then drilling and tapping the front to hold the drives. Heat sink grease was applied to the back of the gecko's and I have not had a problem. The drives have never heated to the point to make me think they are to hot.
Art
Heidenhain iTNC 530 G200(pecking cycle) DULING G-Code Programing 3 02-02-2011 09:27 PM
G320 heatsinks beezerlm Gecko Drives 2 01-09-2008 11:49 PM
Heatsinks? obscurity PicStep Controllers 3 08-28-2006 09:47 AM
Zip Drives Mortek Haas Mills 1 08-02-2006 02:42 AM
Can someone help me with these motor/drives, I think the drives are dodgy? Darc Stepper Motors and Drives 1 07-23-2005 06:31 PM
