12-01-2008, 01:43 AM
Originally Posted by LaserImage I am using Keling KL23H276-30 steppers, wired bipolar parallel. They are 4.2 amps/phase so according to the 540 manual I should use a 4.2k resistor - but - the drives only put out 3.5 amps so should I use a 3.5k resistor instead? What about wattage? Does it matter how many watts the resistor is rated?
Thanks!
Gary |
If you go beyond the 3.5k you will bypass the current reduction feature which is not a good idea. I believe that 1/4 watt is the proper size because it will fit inside the db9 connector. In another thread mariss stated that the 1/2 watt is physically larger and will potentially short out causing all kinds of problems.
Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
