Old 11-29-2008, 09:21 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Gecko 540 and Resistor question
Right now on my machine running a Gecko 540. I have three (3.3k) resistors installed on all axis. So I'm not at 100% efficiency as far as resistors go.
I have in the shop a few 3.6 K resistors. I tried to order 3.5 K but Mouser didn't have them (Still don't). I know the 540 will only output 3.5 Amps per axis. Will I severely damage anything with the 3.6 K resistors? I can't find the 3.5 K and I need to get the machine running.
Will I damage anything on the 540 or the steppers?
-Jason
Old 11-29-2008, 10:13 AM
rowbare is on a distinguished road
With the 3.3k ohm resistors you are down maybe 6% compared to 3.5k ohm resistors why risk it?
Is there room in the connector to add a second resistor? You could always add a second resistor in series to get to 3.5k, or you could hand select from a batch of 5% 3.3k resistors to get some that are at the high end of the tolerance range.
Old 11-29-2008, 10:40 AM
acondit's Avatar
acondit is on a distinguished road
Jason,
I am with rowbare. I wouldn't risk damage to the G540 by using more resistance than Mariss recommends. I recall that Mariss said using no resistor (almost infinite resistance) results in the automatic power reduction failing to work.
Maybe Mariss will chime in and tell us what the effects of using 3.6K resistors would be.
Alan
http://www.alansmachineworks.com
Old 11-29-2008, 12:15 PM
CarveOne is on a distinguished road
If there is room for two resistors I would rather parallel two values that are relatively close together to give 3.5K ohms or just a little under 3.5K ohms. Two 6.8k in parallel will give 3.4K. 7.150K in parallel with 6.8K gives 3.485K.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 11-29-2008, 08:54 PM
Gold Member
Mariss Freimanis is on a distinguished road
You won't damage anything with a large resistor (>3.5K). You simply won't have standby current reduction and your motor will run hotter. Digikey has 3.48K 1% 1/4W resistors at $0.49 for 5 pieces (Digikey part number 3.48KXBK-ND).
Mariss
Old 11-30-2008, 12:04 AM
Thanks Mariss!
Thanks everyone else for posting. I always used Mouser, so never checked Digi.
Thanks,
-Jason
Old 11-30-2008, 12:33 AM
*Registered*
poordumbbastard is on a distinguished road
Question Did you ever figure out your EMC2 problem or is it still giving you fits?
Jason,
I want to run the same setup you have but do not know if its a good idea since you have had so many problems.
Please let me know how your system is working now.
PDB
Old 11-30-2008, 09:39 AM
Poor- I am going to be working on it this week. I have a new video card that came in that i'm about to install. I also want to get the 3.5 K resistors to make sure that I'm getting all the amps possible.
-Jason
gecko resistor need verification dertsap Gecko Drives 9 08-15-2006 12:31 AM
Braking resistor question Syp Servo Motors and Drives 4 01-20-2006 09:52 PM
resistor question plast744 General Electronics Discussion 8 07-10-2005 02:20 PM
Steppers and resistor-question. viktorcnc Stepper Motors and Drives 10 04-05-2005 03:38 PM
Resistor for gecko bgolash Gecko Drives 1 12-13-2004 01:07 AM
