Yes I read the manual and posts. but I have never built before and i need to know im looking at the right numbers. I am hooking a KL23H286-20-8B Link up to a G540. Reading the G540 manual and assuming i am wiring in parallel would i use the 2.8 number and purchase a 2.8k resistor. |
| If you have it wired as parallel, than that is correct. If you are series, then you would use 1.4K. Read http://www.geckodrive.com/upload/Step_motor_basics.pdf to determine how you have the motor wired. |
| ok thanks i was getting confused. First build here and after reading i needed a resistor I thought no problem. When i looked at mauser I was presented with a menu of types. I wasnt quite sure if there was yet another formula i needed to figure out what to get. Thanks I appreciate the help. |
| bullet, Here is the resistor you need from Digi-Key. If you don't get it from there then it will at least give you a good idea of what it should look like. http://search.digikey.com/scripts/dk...me=2.80KXBK-ND Marcus |
Not the cheapest but they are available!
__________________ Cheers, Bob http://www.ocm.com.au/wordpress/ |
| Need Help!- Retrofit with G540 possible? | mickenordin | Gecko Drives | 6 | 01-10-2011 01:45 AM |
| g540 | Scooby Doo | Gecko Drives | 62 | 05-17-2009 02:44 PM |
| Anyone get the G540 working? | Fixittt | Gecko Drives | 10 | 05-08-2009 10:12 AM |
| A couple of G540 questions | cyclestart | Gecko Drives | 11 | 10-14-2008 01:51 AM |
| Setting up the G540 | boxwood | Gecko Drives | 4 | 09-15-2008 01:44 PM |
