Old 10-04-2008, 08:15 PM
gunlocators is on a distinguished road
Need help Fast on 540
I have a 540 and memo 23 282 steppers 48v ps schematics call for 1/10 to 1/2 watt resistors what size do I need and will any one work from radioshack or OD there other specs the resistor must have thanks in advance
Old 10-04-2008, 08:50 PM
Fixittt is on a distinguished road
what amp rating are your steppers?
my 269`s are 2.8 amp steppers. so you would need 2.8K or lower resistors. My local rat shack only had 2.2K so I used those to get up and running. the resistors will be rated in wattage on the package.....
Its a fair assumption to not guess at this. You need to know the ratings on the steppers. Damage can happen.
Old 10-04-2008, 11:46 PM
I must be missing the amps it is KL23H276-30-8B (1/4" Dual Shaft with flat) Specification Price: $39
On KelingInc.net site
Old 10-04-2008, 11:55 PM
Ok I think I found the AMP Ratings
UniPolar 2.7V 3A
BiPolar Series 3.86V 2.1A
BiPolar Parallel 1.93V 4.2A
Found Info at http://www.kelinginc.net/KL23H276-30-8B.pdf
I do not know how which setup uni bipolar series parallel to use
The which resistor to get
Old 10-04-2008, 11:57 PM
jalessi's Avatar
jalessi is on a distinguished road
Smile
If you wire them in bi-polar parallel they are 4.2 amp
Since the G540 max output is 3.5 amps you would use 3.5K resistors to obtain maximum performance with the combination you have.
Jeff...
Old 10-04-2008, 11:58 PM
jalessi's Avatar
Smile
The G540 is a bi-polar drive you can not wire it for uni polar.
Jeff...
Old 10-05-2008, 01:06 AM
Jeff my Yahoo seems to be not working thank you for the info Now I have to learn to wire the 8 wire steppers to the connector properly
Old 10-05-2008, 10:49 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Gun- I have the same set-up as you:
Pin 6: Brown/Orange
pin 7: Black/White
pin 8:Blue/Yellow
pin 9: Red/Green
Pin 1 to 5 : 3.5K resistor (2,3,4 not used)
This set-up flies on the 540! Trust me
-Jason
Old 10-05-2008, 03:58 PM
One more question I went to radio shack biought 2 packs of resistors. Both are 3.3k 5% Tolerance one set is 1/4 watt the other 1/2 watt. Which would be better to use.
Old 10-05-2008, 04:09 PM
TOTALLYRC is on a distinguished road
Post Which watt is best.
See your first thread for the wattage.
It won't make a difference. All that the resistors due is set the current limit in the hardware. They are not in the motor circuit they are just controls so you don't have to worry about burning them out.
I would use a ohm meter to verify the resistance before using them.
It doesn't happen often but sometimes they get packed wrong and you would not want to over amp the motors.
Mike
  #11   Ban this user!
Old 10-05-2008, 04:10 PM
jalessi's Avatar
Jason,
The half watt resistors are double the capacity, so use them even though it probably wont ever make a difference.
Jeff...
  #12   Ban this user!
Old 10-05-2008, 04:13 PM
jalessi's Avatar
Smile
TOTALLYRC Mike,
Sorry. I did not mean to step on your toes.
I was posting a answer the same time as you did.
Jeff...
How fast is this? jmytyk DIY-CNC Router Table Machines 8 02-07-2009 06:41 AM
How fast can a bit cut camcam Open Source CNC Machine Designs 5 05-24-2008 05:07 PM
How Fast is Your Joe bearwen Joes CNC Model 2006 4 08-29-2007 08:29 PM
How Fast is too fast? lgalla Linear and Rotary Motion 2 04-29-2007 08:38 AM
Do you have a fast DSL? Help! ESjaavik CNCzone Club House 11 08-18-2004 10:25 AM
