I fired up my plasma cutter and homed the machine. After homing I went to move the Z axis (which had just homed) but it would not move. The stepper was not powered up as I could spin the stepper by hand. I popped the hood of my electrical box and the Z axis drive has both the green and the red leds lit. I powered down and waited a few minutes then powered back up. The red and green leds were lit up as before. The X and Y axis function normally and have the usual green led lit. The drives are all powered from an Antek power supply. Update After reading the manual again I disconnected the stepper and powering up I get a green led only, so I have to assume the problem is somewhere in the Z axis stepper motor or wires... I still wonder why the green and red leds were both lit? Thanks John Last edited by Big John T; 10-02-2008 at 08:51 PM. Reason: New Info |
| Mariss, After further investigation I have the following. The Z drive is the one with the red fault light on (all 203v's). If I disconnect the Z stepper at the stepper I get a green light. If I connect the Z stepper to the X cable at the stepper I can run the Z stepper fine via the X drive. If I connect the Z power plug (at the drive) to the Y drive I can run the Z stepper fine via the Y drive. If I disconnect either of the A phase wires at the drive the red led does not light up. I'm down to the drive unless I missed something? Thanks John |
| Can you run the X or Y steppers with the Z drive?
| I have not tried that Gerry, the wires were too short. I assumed that if I could run the Z stepper with the Y drive that everything was ok from the drive plug to the stepper and both the X and Y run fine... or did I miss something? John |
| Unless I've missed something, you haven't ruled out the Z drive as being faulty?
#11
| It looks like you've determined the Z drive is bad, but you haven't tried it with another motor to confirm it.
#12
| It could actually be a connector on the drive itself. I had a batch of poor connectors once. I think they were on 201's though. till, these things are mass produced, so faulty connectors can pop up. With the drives powered down, check the resistance in all motor circuits. Right at the pins on the drives. Check both A's. Then the B's. This may not work as well if you have three different sized motors, but if they are alike and you get a different reading on one, that will help narrow down the troubleshooting. BTW, here is that PDF I mentioned, just to get it some airtime off the Yahoo group.
__________________ Lee |
| New SX3 (green with a little rust red) | Yojinbo | Benchtop Machines | 3 | 09-13-2007 12:10 PM |
| Easy Being Green...& Your Job | fizzissist | Environmental & Alternate Energy | 16 | 05-22-2007 01:15 PM |
| green as they come | SILVERBACK | Industrial Hobbies (Support forum) | 6 | 09-25-2006 07:34 AM |
| So New, I'm as green as a Martian | Micro Rotors | DIY-CNC Router Table Machines | 35 | 09-14-2006 07:22 PM |
| green as grass | jonandyev | Stepper Motors and Drives | 4 | 04-19-2006 02:04 PM |
