Old 09-30-2008, 01:22 PM
CoAMarcus's Avatar
CoAMarcus is on a distinguished road
G540 Mach3 XML File
Here is the G540 Mach3 XML file for the REV3 G540 boards. This is courtesy of Dan Mauch at Camtronics who was one of our beta testers and was kind enough to provide this to us. If you guys have any questions about it, feel free to ask.
The file is on the "Application Notes" page of our website and is labeled "G540 XML File".
Application Notes
Marcus
Old 11-06-2008, 10:43 PM
CS900's Avatar
CS900 is on a distinguished road
sorry, I'm a complete computer newb, how/where exactly do you install this file?
Old 11-07-2008, 08:39 AM
dfurlano is on a distinguished road
Go to your Mach3 folder should be c:/mach3 and this file replaces the mach3mill.xml file. But instead of overwriting the .xml with the new one I would suggest that you rename the existing mach3mill.xml to mach3millold.xml then just copy the new one into the folder. That way if you need any parameters from your old set up you can look inside the old .xml file.
If you don't know this file contains all your setting for Mach3 and is in a special text format that can be read if opened.
Old 11-07-2008, 05:43 PM
cnc1881 is on a distinguished road
Hello anyone. Mach3 & Gecko driver can be operated with MN400E controller which was made by Microkinetics corp (www.microkinetics.com) ? thanks ,Ajdcnc.
Old 11-08-2008, 12:38 AM
CS900's Avatar
your the man! thanks
Mach3 xml file for use with a laser dmauch Laser Engraving & Cutting Machines 0 07-12-2008 10:50 AM
I need help for this file work with Mach3 newla Mach Software (ArtSoft software) 4 12-03-2007 06:13 AM
Mach3 won't cut this file smoothly Salty72 Machines running Mach Software 2 11-21-2007 08:17 PM
Mach3 / Bobcad V21 file help Dfennell Mach Mill 11 03-25-2007 01:48 PM
Mach3 xml file Ed Williams Mach Mill 2 04-07-2006 08:50 PM
