| Hi all, been a while since I've been on cnczone........ I am trying to troubleshoot my Z axis. I built the machine a few years ago.....used only from time to time (once a month?) I am using it more often now (daily). Everything worked great while trying to design my cabinet drawer fronts. I routed designs in 2 draw fronts out of cherry wood (after doing several tests/changes in mdf first) and they looked good to me (but not to my wife so I made a final mod and GROWL, down into the wood the bit goes!!!!!!!!!The Z axis only moves in one direction (down) no matter what I tell it (in Mach2 MDI or trackball). I'm using Mach2 6.11, homemade BOB, 3 Gecko G201's PK266-E2.0B's wired bipolar parallel, G201's rigged for 2.66 amps, ~48v powersupply @ 10amp. Windows XP sp2 on a 2.8ghz Intel P4, (NO internet connection). I have tested the BOB using PARMON and all seems well with it. I have tested for continuity on the Z axis power cables (from G201 to motor) I have exchanged the y and z axis cables at the motors (have mollex connectors at motors) and the problem follows. I have tested the dir pins at the Z axis G201 (Drive Power Off) and it follows Mach2's command (0v, -5v [with DMM common to G201 common]) depending on the direction +Z or -Z Could it be the HCPL-2531 opto-isolator in the Z axis G201? I have searched cnczone for opto-isolator and the like and did not find that the G201's have had this problem with others, is this so? Last edited by Clyde; 08-11-2008 at 12:55 PM. Reason: Change title |
| I ran another test today. I switched the 2531's between the Y and Z G201's. The problem moved from the Z to the Y axis...............Yep, that's it. Glad I ordered 10 512-HCPL-2531's yesterday just in case. P.S. makes me a bit nervous now, since I don't have all that many hours on them. |
| I replaced the bad opto-isolator in the Y axis (Z opto moved to Y during last test). It went both directions after the replacement, but missed steps. I replaced the replacement (had bought 10) and it still was missing steps (and growling). I replaced bearings on either end of the screw drive, because it sounded like a bad bearing, even though I could not believe a bearing would wait and go out right then just to make my day miserable. Nope, still missing steps and growling. Set the pulse width in the motor tuning to 4 us, works fine now. hmmmmm, could the 512 in front of the 512-HCPL-2531 mean it is only good to 512k instead of 1024k (1mhz)? |
| Tags |
| g201, no dir, opto-isolator |
| Need Help!- g201 | bbrown2005 | Gecko Drives | 1 | 04-05-2008 08:01 AM |
| DNC software and isolators | Caprirs | Machine Problems, Solutions , Wireless DNC, serial port | 16 | 03-06-2008 10:09 PM |
| 3 x G201 on eBay | guja011 | Gecko Drives | 1 | 02-18-2008 09:48 PM |
| Help for best G201 set up | tonyno | Gecko Drives | 0 | 03-10-2006 06:24 AM |
| Opto-22 ? | andy55 | General Electronics Discussion | 1 | 01-07-2006 04:08 PM |
