The Geckos need 15V minimum, and your motors probably need much more to get higher speeds. What voltage are the motors rated at?
I've got a set up I've been playing around with running for a mobile work shop application.
2X 24 V, 6 A motors
1X 12V car battery
2X Gecko 203V's.
1 Step-Up 12/24V DC converter rated for 300 W, 12.5 Amps output continuous.
Having some issues with the drives quiting at high speeds steady state when both motors are running. I've seen improvement by adding 470 uF caps to the drive inputs, but no improvement by adding a 10000 uF to the Step-up converter output. I guess following the
C = 80000*I/V thing this should be more like 40000uF, but I'm wondering if it's more I'm pushing the limits of my step up converter and that's what's causing the drives to shutdown, but I think it might be something else.
I've also tried subbing in a 12V 20 A regulated power supply for the battery and seen similar problems.
Thoughts?
-Nick
The motors are 6 A,0.6 V, 0.1 Ohm resistance (0.4 mH) motors designed to be run at 24 V like I'm doing.
Your right, the Geckos need more than 15 V, so I'm running them with a 12 to 24 V DC-Dc step converter powered by the battery.
-Nick
Poptarts,
Why not use two batterys in series, that might be better than the dc to dc inverter?
JoeyB
Agreed on the batteries in series, far fewer headaches there, but I'm trying to keep the weight down to make it easier to move. Perhaps I should run some tests with two batteries to see performance differences.
-Nick
Check it out
http://tinyurl.com/56kqna
Nick,
http://tinyurl.com/5n5p2u
Get one of these and rework a old GM alternator.
JoeyB
Or just mount one of these!
http://tinyurl.com/5zglty
JoeyB
That battery is cool, and it's getting me thinking I might try something like that.
but it still doesn't solve my problems with the motor cutting out. Like you said, two batteries in series ought to prove if it's the step converter or something else, like the two motors BEMF messing with each other, or the controller which in the past hasn't been a problem.
Just one motor gets up to speed (~1000 rpm) and then poops out in a couple of seconds, so I guess it's either the Gecko over heating (I have it heatsinked and fan cooled set to 6 Amps) or I don't have enough a big enough Cap on the system in the system to run it at the right speed, but like I said earlier, adding a 10k uF the cap didn't seem to do anything, but I may need to add a 20k uF for each motor.
The alternator might work out well in a car application. But I bet I'd still need to do some power conditioning stuff.
-Nick
How may amp output is your converter?
JoeyB
The DC-DC converter is 12.5 Amps output
-Nick
Guessing the low voltage may be causing the motors to draw more current than the drivers may be able to handle.
Or the inverter is outputing really dirty D.C. running at its maximum capacity.
You will have a much better answer once you try the two battery combo.
Might suggest using a 36 volt inverter however it still only has a 270 watt continuous rating.
JoeyB
