Old 07-09-2008, 06:28 PM
Alex_Cole's Avatar
Alex_Cole is on a distinguished road
Will This work?
I am trying to build a reset circut and I am not sure if this will work or not.
Technically I have 3 drive I need to tie together so the pin5 shown would be split and go to 3 drives.
I am not that good a coming up with circuts and I don't want to fry anything.
The desired result for how this would work is the following.
When the drives 1st get power they will not be active due to no 5+dc on pin 5. When I press the momentary switch down and hold then the LED should light and the drives should activate and then pin5 will stay at 5v leaving the led lit to let mek now that the drives are up and not faulted.
Then if a fault would occur then the led would go out and the other two drives would be turned off by pin5 going back to 0vdc.
I have been thinking about this and I think it should work but wanted to ask before I build anything.
AC
AC
Has anyone seen my pillow?
Old 07-12-2008, 10:13 AM
Alex_Cole's Avatar
Ok....so it didn't work. I removed the resistor and led so now I just have the switch. That didn't work either but I ran into a problem that maybe someone here could explain.
I tried taking 5vdc from my powersupply and tried to use this for the 5v to enable the G340 drives. But this would not enable the drives? So I tried taking the 5v from my breakout board and this would not enable the drives either but it would allow the button the enable activate the estop when the button was released.
What I want is the push button to feed 5vdc to the drives and set the system so that the estop could be turned off. Then the drives would hold the line at 5vdc keeping the estop from triggering. Then if one drive faulted they all 3 would stop and it would trigger an estop in Mach3.
I found that the only way I could get the drives to enable was to pull the 5v from the encoder 5v on one of the drives and then feed this through the momentary switch. Then split this out to the 3 drives along with feeding it to the breakout board to go to mach3.
This works in linking the 3 drives together and if one faults then they all 3 fault but it will not trigger an estop in Mach. The software keeps on going?
What am I missing? Anyone have any ideas?
AC
AC
Need Help!- Would this work? rich200313 Controller Cards 4 07-16-2008 05:30 AM
Newbie- Work Planes / Work Coordinates MICFDI Esprit 9 05-12-2008 12:35 AM
Some of our work. TAJS Machine Created Art 9 03-31-2008 11:42 PM
Would this work? MrHorsepower PIC Programing / Design 2 11-05-2007 09:58 AM
will this work? campaX DIY-CNC Router Table Machines 8 05-17-2005 01:42 PM
