Page 1 of 9 1234 ... LastLast
Results 1 to 12 of 107
Thread: Ongoing Saga of a CNC Gone Crazy
    ProDrawerCom
    Apr 2006
    Suggestions for changing or checking settings have been made but this system has operated flawlessly for over a year with SketchUp as the CAD, SheetCam as the CAM, Mach as the operator, a Bob Campbell Designs breakout board as a liaison between an old PC and three Gecko 201s. The first sign of trouble presented while my Bosch 2-1/4 HP router, cutting through machinable wax, began a quick succession of jolts about 1/4" in length from Xnorth to Xsouth and back. No X movement was on the script at the time. The Y motion which was appropriate continued smoothly. Along with the jerky X motion was a grinding noise similar to that noise which occurs when steppers are trying to overcome an immovable object accidentally left in their path. The work piece was ruined and an emergency switch was slammed. Upon manual jogging, the X stepper would respond appropriately or the router would go in the same direction whether the Xnorth or Xsouth key was depressed. On some occasions the router would not move at all but a weak hum would emanate from the X motor. It was suggested by the forum that the Gecko could be removed and sent away for analysis. While proceeding to remove it, I discovered some less-than-tight wires on the Gecko bus boards. They were tightened and the code was run again. It appeared that all was well so I posted that the problem had been resolved. I was wrong. The grinding noise was gone and the left to right shuttering had ceased but a more subtle manifestation of the problem appeared. The wax project piece was now deformed by some errant tool paths that looked for all the world as though the wrong code had been loaded. But it had not. Marriss's last suggestion was that the breakout board might be the culprit. Not buying that for a second I put my Z Gecko in place of the X and vice versa. (No easy task in the tight quarters of my system) The Z was clearly not involved in the aforementioned behavior so this should confirm the X Gecko as the offending component. But it did not. The errant g-code continued. I re-ran the DXF through SheetCam. The image produced by that program appeared normal but I regenerated the g-code to rule that out. But my system, again, produced a deformed part. So here I am with most things ruled out. I should try another printer cable for the sake of completion but the breakout board seems the most likely cause at this time. Any input will be appreciated while I correspond with BCDesigns.
    Attached Thumbnails Attached Thumbnails Ongoing Saga of a CNC Gone Crazy-cnc_prob.jpg
    Registered Crevice Reamer's Avatar
    Mar 2008
    This sounds like your computer could be at fault. What operating system are you using? Vista can be flakey. Are you running other programs beside Mach? Like virus protection, internet, etc. Remove everything but Mach. Maybe you could try another computer?
    CR.
    ProDrawerCom
    Apr 2006
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    Old computer with XP. Not even connected to the Internet. Important to remember that the problem is new. That doesn't rule out the computer, for sure. But it doesn't go on the Internet.
    Mar 2008
    Unless you have CHANGED something, then your NEW problem is caused by something OLD gone BAD. ANY other program running, even parts of XP can cause CNC problems. Everything that controls that axis originates in the computer. You need to rule it out.
    CR.
    ProDrawerCom
    Apr 2006
    Just heard from Bob Campbell Designs. He believes the problem is a driver. Can someone, anyone, tell me how to bypass the breakout board? I use a printer cable to the breakout board. I need to be sure it's not the problem.
    While I wait for responses I will rule out the Y drive by doing the same experiment previously performed to rule out the X drive.
    I don't have a spare computer to rule it (the computer) out with. Guess I could reload XP and reload Mach. Jees!!!
    Mar 2008
    Well, at least go into control panel, double click add or remove programs, and see what is IN there. Remove any virus protection, internet or networking programs.
    When Mach is running, you can do control/alt/del to bring up the windows task manager. click on processes and you can see what is running and when.
    CR.
    ProDrawerCom
    Apr 2006
    Well, at least go into control panel, double click add or remove programs CR.
    Will do.
    And for the benefit of anyone else who might be following the thread I have just ruled out the Y driver. My assumption is that the Z driver could not be involved as the profile is made up of only two dimensions: X and Y. One at a time I put those drivers in the Z mount and used the Z driver in their place. In both cases the faulty routine persists. I guess I should post the code in case anyone wants to run it. I guess that's the only sure way to rule out a faulty code. And I realize there are still other components to rule out: the computer, Mach, the bb board, printer cable, etc.
    ProDrawerCom
    Apr 2006
    There were only a few programs on the computer but I removed all not required to run Mach. No change. Task Mgr shows that only Mach is running. The removal of the few unnecessary programs DID seem to make my system run smoother. Could be in my head. But the errant pathway still persists. And by the way-- the pathway generated and followed on the Mach screen is not wrong.
    ProDrawerCom
    Apr 2006
    Really do want to know how to go directly from printer cable to drivers. For now-- going to bed.
    ProDrawerCom
    Apr 2006
    0505: Didn't get any sleep. It just occurred to me how meaningful it is that the errant execution of this code is predictable, repeatable. It doesn't do something different every time. It does the same thing every time. I suppose that an ill performing electronic component would do random acts. This must be why Crevice Reamer suspects the computer and he must be right. So after I get going this morning I'll take my office computer down there and try it. Actually it won't be the first time. A week or so ago I tried this computer but the Mach on it wouldn't work for some reason. I'll try again. But first I'll reinstall a clean Mach.
    Registered LeeWay's Avatar
    Jun 2004
    I suggest you run a driver Test in mach first. Just to see whats up.
    I have some straight pass through BOB's that have no frills. These are easy to come by and are great for troubleshooting a BOB.
    I have had plenty of issues with fancy BOB's and so always suspect them first.
    Bob Campbell is very knowledgeable for sure, but I don't think it is your Gecko's and your test pretty much confirms this.
    When this kind of thing happens, it's always a pain to track down, but you have to do it methodically. I always test and rule out the easiest stuff first. Software. Then cables and wiring. Don't forget the motor wires. A loose one here will cause multiple head scratching.
    Lastly I start swapping electronics.
    It does pay to have spares of everything possible I think. Maybe not motors and drives, but those are swappable for testing anyway, but printer cables, plain Jane Bob, an install of Mach Quantum on the same HD, G-codes that you know for a fact have worked fine in the past etc.
    Lee
    ProDrawerCom
    Apr 2006
    Quote Originally Posted by LeeWay View Post
    You said it brother! This thing's had me thinking seriously about giving up on this hobby. It's so damned frustrating. But I know I can't.
    Before I opened your post I tried switching computers. But again-- Mach won't run my CNC on THIS particular computer. Drives me crazy. We worked on the problem for hours on the Mach support forum. I really do want to give my whole system the middle finger and just walk away and start stamp-collecting or get an aquarium or something. Unfortunately (or fortunately depending on what day it is) it's more than a hobby. It's a potential business.
    So if I can't walk away-- how can I bypass my BOB?
  • Page 1 of 9 1234 ... LastLast
    1. SIEG X3 Budget DIY CNC Conversion Ongoing Project Summary
      By Ninhil in forum X3/SX3/G0619/G0463
      Last Post: 03-06-2007, 07:26 PM
    2. Moving Tormach mill to a basement - saga
      By MichaelHenry in forum Tormach Personal CNC Mill
      Last Post: 02-20-2007, 12:19 AM
    3. prazi mill cnc conversion, ongoing education
      By drwc in forum Benchtop Machines
      Last Post: 06-07-2006, 08:53 PM
    4. First Router - The Saga Begins
      By dighsx in forum CNC Wood Router Project Log
      Last Post: 04-27-2006, 04:50 PM
    5. LPT crazy
      By Lu_ca in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 04-05-2005, 07:17 PM
