This is how I understand the three pots, please re-educate me if I am wrong. I need a scientific approach to tuning the drives for my servos, righ now still a bit hap hazard doing it. Limit - overall power to motor Damp - braking of motor Gain - acceleration of motor or "stiffness which i have no idea what that means Damp and Gain should be close together to quiet the dithering of the motor, too close and get osilation. Gain too high get osilation. I try to set the gain damp as high as can without noise then back off both, then lower damp to aviod osilation. I read a post about walking gain and damp up. firt gain then back gain off, then move damp up, rinse and repeat is this right? Is this correct. I am adjusting my Z axis it is a bit tricky. I notice when motor stops after rapid move it dithers a bit, also there is quite a bit of ticking coming off the servos, I hear some people can get them very quiet. any tips , how to tune appreciated. R Last edited by Rich05; 06-26-2008 at 01:38 PM. |
| Hi, The most scientific approach to tuning Gecko's is to open the case up and find the set-point pins and apply an oscilloscope to view the set-point waveform. I'm buggered if I'm going to undo all the wiring and scrape off the heatsink compound now just to get to the screws at the back. So I'm like you, fiddling in the hope I get it right. I belive that the gain control is like an adjustable spring, it gets the motor to position quickly but overshoots abit then undershoots back and forth until it settles on the correct position just like a car with no shock absorbers. The damping control is exactly like a car shock absorber and controls the springyness so by adjusting this you should get it to a point where when the axis moves to a position you just get the smallest amount of overshoot then the system settles on the correct position straight away. The trouble is that the two controls react together so adjusting one will need adjustment on the other. The dithering you mentioned sounds like it is over-damped or too much gain. More probably the former, my guess is that the axis almost reaches the position but not quite so it is hunting back and forth until it settles. I may be wrong i'm still learning too. It would be nice to here from Marris on how to get the best tuning without opening the case and what you would expect to see/hear if it is not right. Currently I've only finished one axis so I'm still in the building stage. The axis seems to work ok when the motor is at a standstill it makes an urr,urr noise every 10-20 seconds or so. When I rapid and adjust the gain it doesn't seem to make a difference, mine is nearly full up. I have noticed if I get the damping wrong the whole mill makes a noise like I'm dragging a table across a wood floor. What I would like to know is, do these adjustments only affect the drive on a few encoder counts, so rapiding up and down whilst adjusting wont make any difference. What's your opinion? Cheers |
| Servo Tuning Problems? | RYANPB | Gecko Drives | 1 | 11-27-2008 01:43 PM |
| Need Help!- Fanuc Servo Tuning | Michael82 | Fanuc | 1 | 05-21-2008 07:21 AM |
| G320 servo motor tuning | robhrzic | Gecko Drives | 12 | 11-01-2007 02:35 AM |
| Servo PID tuning over a large XY Table | rainman | Mach Software (ArtSoft software) | 2 | 09-21-2007 12:14 AM |
| appropriate servo tuning.... help? | howling60 | Servo Motors and Drives | 6 | 02-27-2006 09:48 AM |
