Hi there, I am working on converting my Sieg X2 Mill in to a CNC Mill. I have a CNC Fusion kit on its way to handle the machanical part. (Ball screw conversion for the X2,with NIMA 23 mounts)(Will be using 400oz Nema 23 steppers.) I am going to buy 3 Gecko 203V's shortly and I am just wondering what is the best breakout board for this setup. ( Power supply and steppers won't be a problem,do I need anything else except the breakout board? ) Any info would be appreciated. Kind regards, Bert. |
| CR, I agree the CandCNC stuff is great! Plug & Play...All the Way!! Mini IO is easy on the Pocket book. I also like the plug in board for Gecko 203V's. Degrom, Arturo Duncan also has a nice selection of BOB's (full 6 axis') He has also introduced an MPG (Manual Pulse Generator) CNC4PC.com You can see by the Photo, I've purchased stuff from both Guys and I have had excellent results. W. Smith Last edited by CNCfun&games; 06-20-2008 at 02:09 AM. Reason: changed CNC zone to CandCnc |
Regards, Bert. |
| I've had good luck with mine. As far as the multi-functions go, as of right now, I'm only using the charge pump, EN & pin 10 as e-stop, and jumper set for com pins to be ground. I'm planning to hook up the limits, coolant relay, and spindle control in the near future. Jack
__________________ Walking is highly over-rated |
Are the motor's up to the task or would you recommend bigger size motor's? I am thinking of using at least 400oz+ steppers on my conversion... (What did you think about your CNC Fusion kit?) Sorry for all the questions,thanks for the replies. |
| The CandC N C system is several easily connected modules and allows building a very professional workstation with independently survivable components. The all-in-one BO boards, If there is a problem, will lose everything. The EZ Plug boards can also be installed onto an available aluminum heat-sink-mounting plate. For some reason this forum converts the name of Tom Caudle's company (CandC N C.com) to CncZone unless you space out CNC as C N C, and that includes the link. CR. |
#10
I'm with CR on this. The CandC_N_C mini-IO with on board logic supply is a really simple solution. I have one on my router and another on my lathe. Unfortunately the cnczone editor keeps changing the URL from CandC_N_C to cnczone, so I can't seem to post a valid link to their website. It is CandC_N_C.com without the underscores. Alan
__________________ http://www.alansmachineworks.com Last edited by acondit; 06-20-2008 at 11:16 AM. Reason: Fix error in cnczone spellchecker |
#11
| CR & Alan, Thanks for the explanation on the URL stuff!! Was beginning to think my cerebral transmission was slipping bigtime! DEGROM, Tom's Gecko "EZ PLUG" dual stepper Interface card is $38. It replaces 24 Hard wired connections ....But ....also includes the Gecko current set function via DIP switches. Can't wait till Tom works his magic on a G250,G251 plug & Play Box, similar to the XYLOTEX System offered previously. Cheers...W. Smith |
#12
I had a look at the EZ Plug stepper interface.(Love the plug and play idea!!!) But you still need a breakout board board,right? Regards, Bert. |
| what USB Breakout Board to by ?? | dbss | General Electronics Discussion | 5 | 01-19-2008 08:54 AM |
| Looking for a Breakout Board | SpeedsCustom | General Electronics Discussion | 14 | 01-04-2008 10:21 PM |
| Breakout board, Relays on board? | Cooper | Open Source Controller Boards | 11 | 06-09-2007 08:55 PM |
| Which breakout board to use | erkiwi | Stepper Motors and Drives | 2 | 05-05-2007 03:08 AM |
| Breakout Board | ckirchen | Product Announcements & Manufacturer News | 11 | 06-20-2005 12:52 PM |
