  #25   Ban this user!
Old 06-22-2008, 09:08 PM
Degrom is on a distinguished road
Originally Posted by Crevice Reamer View Post
In addition to the protection: The 203Vs also morph from microstepping at slow speed to full step at higher speed to provide faster rapids. They have overheat prevention circuitry and run very quietly.
They ARE more expensive, but worth it in SO many ways.
CR.
I noticed the morph function... How does that work? Does it start with micro stepping and then switch over to full steps?
Thanks for the reply.
Bert.
  #26   Ban this user!
Old 06-22-2008, 10:03 PM
Originally Posted by tauntdesigns View Post
I got my motors and power supply from KelingInc
http://www.kelinginc.net/index.html
With the power supply and motors I got, I had to wire the 425 oz/in motors 'Bipolar Parallel' and the 640 oz/in motor 'Bipolar Series'.
Jack
Thanks for that...
Both KelingInc and Homeshopcnc.com are out of stock on the steppers I am interested in.
So I will have to wait a while.
Homeshopcnc has a 570 nema 23 stepper that looks the part to me. I was thinking that I would rather go big and make sure I over power rather than under power with the conversion rather than under power with a 282oz steppers from KelingInc or a 370oz steppers from Homeshopcnc.
I might be wrong... :P
  #27   Ban this user!
Old 06-23-2008, 07:18 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Those 570s will run best (Bipolar Parallel) with 5Amp and 48 volts each. To run 3, you will need a 48 V 10 A power supply. To run 4, you will need 48V and 14 A.
http://homeshopcnc.com/page5.html
CR.
  #28   Ban this user!
Old 07-03-2008, 11:40 PM
acondit's Avatar
acondit is on a distinguished road
Originally Posted by acondit View Post
I'm with CR on this. The CandCNC mini-IO with on board logic supply is a really simple solution. I have one on my router and another on my lathe.
This is a quote from my earlier message, but the link is supposed to be fixed now.
Alan
http://www.alansmachineworks.com
  #29   Ban this user!
Old 07-04-2008, 08:21 AM
Bert.
Yaw! Yes! They are the best of both worlds and do EXACTLY that. So you can set very high resolution, but still have full-speed rapids.
CR.
what USB Breakout Board to by ?? dbss General Electronics Discussion 5 01-19-2008 07:54 AM
Looking for a Breakout Board SpeedsCustom General Electronics Discussion 14 01-04-2008 09:21 PM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Which breakout board to use erkiwi Stepper Motors and Drives 2 05-05-2007 02:08 AM
Breakout Board ckirchen Product Announcements & Manufacturer News 11 06-20-2005 11:52 AM
