  #49   Ban this user!
Old 08-27-2008, 12:03 AM
sunward is on a distinguished road
Okay. A followup.
I went through the machine and everything looked good.
I then contacted Gecko drive and spoke to 2 people in tech support ( forgot their names).
We went through all the settings - from the drives, computer, cnc parts, and even the speed of the machine. I got a list of things to do - from trying to switch the drives again, checking the wires, motors, and changing the drives but not the terminal assemblies. I was about to go through the list when the voltage of the power supply ( that was installed last night) came up. It was 50V DC. As I have an old voltmeter, I thought it was a meter error as the design specs (discussed in this thread) for the power supply should have been correct. Seems they were not.
The power supply has 2x 110V input and 2 x 18VAC output. So, as agreed on this thread, the output would be good. ( I had even contacted the transformer supply company Plitron).
It was not a bad meter.
With 2 x 18VAC, connected in series, the total output of 36VAC would be over 50V DC ( 36 x square root (2) ).
I was ready to order a new transformer when the idea of connecting the input in series came up (This would half the output. The input is 4 wires where you can connect in various ways and different voltage - 115 or 230V ). The 18V x sq rt(2) would be just over 25V DC. Above the minimum for the drives and in the range for the motors. I was informed the maximum torque would be lower, but felt this was a good option.
I connected the input in series, and checked the voltage - 25V DC.
The machine ran for 2 hours without a problem. Will see if there are any more problems later on.
Feels good.
Angelo Castellano
Sunward Aerospace Group Limited www.sunward1.com
  #50   Ban this user!
Old 08-27-2008, 11:12 PM
Ran the machine again for a few more hours.
No problems. Looks like it fixed the problem.
Oh, feels so good.
Angelo Castellano
  #51   Ban this user!
Old 08-28-2008, 06:25 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hooray! Glad to hear you have solved the problem.
CR.
How to determine the Holding Torque Requirement? joprinz Stepper Motors and Drives 0 11-19-2007 04:59 AM
No holding torque or movement with G201 patdttr225 Gecko Drives 6 09-02-2007 11:16 PM
Holding torque? Marc Servo Motors and Drives 23 08-22-2006 03:19 PM
Holding torque Ncm vs Oz/in George Stepper Motors and Drives 3 12-14-2005 02:58 AM
Holding Torque (please help) dowling177 Stepper Motors and Drives 2 01-18-2005 01:59 PM
