Old 05-18-2008, 11:00 PM
bubbax1 is on a distinguished road
g210 disable signal
Can the disable signal be run through a limit switch?
And if so can it be in series with the ground signal from the
controller so that I can still use my e-stop switch to disable
all axis.
I am running a software similar to Camsoft with the Galil card
driving an Ah-ha 3 axis control box.
I am also already using a g210 on my 4th axis, but I never hooked
up the disable because I was unsure if it would cause problems.
I have a full time manufacturing business making my own product and
can not afford down time.
I am so glad I found this wonderful forum, hopefully I can help somebody else
someday the way you are helping me.
Thanks,
Joe
Old 05-19-2008, 12:12 AM
Al_The_Man's Avatar
Depends on how you have the present E-stop circuit set up, usually you want to kill the power to the drive. But there is also a forward/reverse L.S. input for each axis on the Galil card, and a Amp enable output from the Galil to the drive that can be used.
There are a few ways it can be set up.
Need Help!- Disable FAPT F3T Pxt Fanuc 1 02-27-2008 09:28 PM
Disable switches swarfmacdaddy Gecko Drives 9 10-24-2007 03:28 AM
Disable with Mach belli Mach Plasma / Laser 3 07-14-2007 04:53 PM
Motor Speed of G210/G210 can be reach? phx2002 Gecko Drives 1 01-20-2007 07:53 PM
Gecko 201 disable? LEWENZ Gecko Drives 6 01-12-2007 10:24 PM
