Ed, Is your lathe equipped with a 90 volt dc motor? I am going out on a limb here. Most likely your lathe has 110 -120 volt ac motor and if so the Gecko is not going to work. Please post the motor size in horsepower, voltage and amperage. Then it will be easy to suggest a control solution. Jeff... |
Ed, Lee is 100 percent correct. I apologize for not completely reading your question. If you are using a servo motor to drive your spindle, the gecko will work if within its operating parameter. Lee's question about horsepower with be the deciding factor. Jeff... |
| What I'm doing is adding it to my cnc mill. It will be used like a lathe. My cutter will be mounted to the side of my router. I hoping I can use the spindle setup in Mach3 to do this. I using a small 3" chuck. I have not purchased a motor yet. But I already have and extra 320. What size motor would be good for this and what gearing should I use. Thanks Ed |
| Possible Gecko Drive? | juzwuz | Gecko Drives | 7 | 03-19-2008 12:00 PM |
| Gecko drive problem | contractdesign | Bridgeport and Hardinge Mills | 8 | 07-25-2007 09:54 AM |
| Which Gecko Drive | Lloyd | Gecko Drives | 5 | 05-31-2006 02:35 AM |
| Can Gecko drive this motor? | N4NV | Gecko Drives | 8 | 02-27-2006 11:55 PM |
