Old 05-07-2008, 10:16 AM
Preston E is on a distinguished road
Gecko 340 limit,gain,damping zero position?
Hello,
I have several 340's that were used by a friend and the settings are in the mid range approximately.
The Installation Notes state to turn the Limit trim pot 1/4 to 1/2, Gain turn off, and Damping 1/4 turn.
Where is the off position. Fully clockwise or fully counter clockwise? And is this true for each of the 3 trim pots?
I've looked at all of the Gecko instructions and cannot find this anywhere.
Thanks for the help,
Regards,
Preston
Old 05-07-2008, 04:10 PM
Ok, they were mounted in the control panel and I could not see them well at the angle and placement.
Had to take one out and with my optivisors on I could see the little 1,2,3...
Turning all the way counter clockwise zeros the little devils...
Regards,
Preston
Gain, Damping, Limit THend Gecko Drives 1 04-10-2008 04:17 PM
Filling steel tube with cement for damping/mass? stag53 Mechanical Calculations/Engineering Design 6 11-26-2007 02:39 PM
Vibration Damping Geof Mechanical Calculations/Engineering Design 3 11-08-2007 03:44 PM
Newbie questions gecko drive limit ? Calico Gecko Drives 0 04-03-2005 06:15 AM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 09:42 PM
