Old 05-04-2008, 06:00 PM
glengen3 is on a distinguished road
GECKO W/202 AND PMDX 131
I HAVE BRIDGEPORT BOSS CNC WITH TWO SIGMA STYLE AND ONE SUPERIOR STYLE STEPPERS. ITS POWERED BY 2 22OV/ 48V 1OOO WATT STEP DOWN TRANSFORMER. BOTH PRIMARIES AND SECONDARIES OF THE 2 TRANSFORMERS ARE WIRED PARALLEL AND IN PHASE WITH EACH OTHER. THEY FEED THE POWER TO A PMDX 135 FULL WAVE BRIDGE RECTIFIER THAT PUTS OUT 70VDC, TO POWER 3 7AMP PER PHASE GECKO 202'S. 118VAC POWER IS DRAWN OFF THE CENTER TAP OF BOTH PRIMARIES AND IS USED TO POWER A PMDX 131 BREAKOUT BOARD. THE PROBLEM IS THAT THE STEPPERS ONLY PULLING ABOUT 1.9 AMPS WHEN STEPPING. THEY HAVE VERY LITTLE HOLDING POWER , AND ALMOST NO TOUQUE WHEN STEPPING.
ALL VOLTAGES HAVE BEEN CHECKED AND APPEAR TO BE CORRECT.
THEY ARE WIRED AS FOLLOWED:
SIGMA
3 TO PHASE A+
1 TO PHASE A-
4 TO PHASE B+
2 TO PHASE B-
7 JUMPERED TO 8
5 JUMPERED TO 6
SUPERIOR
A+ TO 7 AND 4
A- TO 5 AND 8
B+ TO 1 AND 2
B- TO 6 AND 3
WHY DON'T HE STEPPERS HAVE ANY POWER?
ARE THE TRANSFORMERS WIRED INCORRECTLY?
HOW SHOULD I CONFIGURE THE PIN AND MOTOR TUNING SETTINGS ON MACH 3.
THE GECKOS HAVE NO CURRENT LIMITING RESISTORS.
Tags
gecko and pmdx trouble
Mach3 + PMDX-122 Burn Mach Software (ArtSoft software) 0 01-06-2008 03:33 PM
Making a Relay with the PMDX-122 Burn General Electronics Discussion 0 03-27-2007 10:02 PM
PMDX-122 BrakingBoard and MSD980 Driver Goose80 Servo Motors and Drives 1 02-16-2007 05:58 PM
advice sofware with gecko 202 & pmdx board for mill ajitsingh Machines running Mach Software 2 08-10-2006 12:09 PM
