I manage to jog all axes, but only two at a time. I can jog x and y, but not z. Then I reboot my computer, shut down driver power supply, and I can jog y and z, but not x. I have COMMON over usb port, 60V 15A PS, 3 1200 oz/in steppers. Controller is athlon xp 1900+ with 512 MB RAM. I double checked ports and pins, and try warious combinations on output pins. All three geckos are heatsinked on one big heatsink, and auto current reduction is enabled... I dont use breakout board, pinned them directly from lpt port. I did not connect ground from to any pin, could that couse the problem? Is usb 200ma to low for three geckos? What is the minimum miliamper value to run a gecko? Any help is appreciated... Last edited by bebson; 04-25-2008 at 05:43 PM. |
| If you're not getting a full 5V from the parallel port, then the G201's won't work well. They usually need a breakout board to supply them with sufficient power.
| Tuning 201's | olf20 | Gecko Drives | 3 | 03-30-2008 10:06 PM |
| Where to buy a good power supply for gecko 201's | journeyonline | Gecko Drives | 1 | 04-02-2007 07:57 PM |
| How do I gang axes? X X Y Z not working. | Javelin276 | LinuxCNC (formerly EMC2) | 4 | 03-06-2005 10:32 PM |
| Gecko 201's with TCNC | jimini | Gecko Drives | 3 | 10-24-2004 02:24 PM |
| GECKO 201's ? | ninewgt | Gecko Drives | 3 | 06-13-2003 01:49 PM |
