Old 04-25-2008, 09:31 AM
Grebbo's Avatar
Grebbo is on a distinguished road
My Gecko G203V heat sink set up
Hi everyone,
I thought I would share my new Gecko 203v heat sink setup, this is an interlocking two part heat sink that is particularly designed to accept 2 x 80mm fans on either end, making it very efficient, its going in to my new controller box that I’m currently setting up. Once installed I will put some heat transfer compound between the drivers and the heat sink itself.
Name:	Heat sink 01.jpg‎
ID:	58365   Click image for larger version
Name:	heat sink 02.jpg‎
ID:	58366   Click image for larger version
Name:	heat sink 03.jpg‎
Old 04-25-2008, 01:09 PM
CoAMarcus's Avatar
CoAMarcus is on a distinguished road
Looks pretty snazzy. I take it the other fan will be directed to suck air out of there, and not opposing the other fan. If not, then may the best fan win. ;-)
-Marcus Freimanis
Old 04-25-2008, 07:02 PM
Grebbo's Avatar
Hi Marcus,
Totally correct, both fans are facing in the same direction, that is one is “sucking” and the other is “blowing” both fans are indentical, I had them connected to a bench top power supply and they work well, so well in fact that the heat sinks dropped in temperature noticeably! It might be a bit of an over kill do you think???
Old 04-25-2008, 07:27 PM
CoAMarcus's Avatar
Grebbo,
No, there really is no such thing as too much cooling for drives. At what current do you plan on running them?
-Marcus
Old 04-25-2008, 08:07 PM
Grebbo's Avatar
Well, the steppers I have are 640 oz-in rated at 6.3A @2.3volt so I was going to restrict tem to 6 Amp (at 50 volts) by use of a 270 K-ohm resistor over pin 11 and 12 on the drives, that is correct isn’t it,
Grebbo
Old 04-28-2008, 01:46 AM
phomann's Avatar
phomann is on a distinguished road
Originally Posted by Grebbo View Post
Hi everyone,
Snap! I've got a similar setup with the same heatsink modules, although I've mounted 2 G203V on each side with a breakout board on top. There is room for 2 more Geckos, as the Heatsink runs front to back in the enclosure such that air doesn't get sucked into the enclosure, but passes straight through the heatsink.
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com
Old 04-28-2008, 02:01 AM
Grebbo's Avatar
Hi Peter,
The reason I went with this type of heat sink is that I thought you could mount an additional drive quiet easily if I went to 4 or 5 axis set up, just need to flick it on to its side, so its good to know that someone else is using the same set up, also I like your idea bout mounting the BOB on top of the sink as well, are you having any problems with heat??
Old 04-28-2008, 03:34 AM
phomann's Avatar
No problems with heat. But then I'm only using 3A Steppers.
Cheers,
Peter.
Old 04-28-2008, 03:41 AM
Grebbo's Avatar
Hi Peter,
I just checked out your site! Good to see some Aussie sites that are getting in to the CNC market! good onya mite!! Expect a purchase soon!
Old 04-29-2008, 01:53 PM
Big John T is on a distinguished road
Sweet setup. Here is what I used...
ID:	58652   Click image for larger version
  #11   Ban this user!
Old 04-29-2008, 09:21 PM
Grebbo's Avatar
Hi Big John!
nice setup, I see you went for the "old computer" case setup,nice.. what steppers are you running on your 203s?
  #12   Ban this user!
Old 04-30-2008, 09:27 AM
I'm using AutomationDirect STP-MTR-23079 MOTOR, STEPPER, 276 OZ-IN, NEMA 23, BIPOLAR $39.00
I can move my plasma torch at 500IPM with that setup and 60 volt power supply... I think the last time I calculated the rpm it was in the 1000-1200 range and smooth as silk throughout the entire range...
John
to heat or not to heat - that is the question? stirling Stepper Motors and Drives 15 09-04-2007 04:44 AM
X3, Gecko G203V and what else.... KOS Benchtop Machines 10 05-27-2007 11:08 PM
Gecko 320 was working.. heat? wildcat Gecko Drives 7 01-03-2007 08:28 PM
Gecko 320 Heat Sink ?s Bird_E Gecko Drives 2 03-13-2005 02:09 AM
Heat sink mounting questions CactusChip Gecko Drives 3 01-31-2004 01:43 AM
