Old 08-06-2004, 01:48 PM
Gold Member
CRFultz is on a distinguished road
Current Set Resistor
I just ordered my g201's and I would like to verify the requirement for the current set resistor.
The stepper's are:
x and y:
6 wire 4.8v @ 2.53 amps (nameplate rating)
I will be hooking these up full winding to a switched 48 volt 25 amp power supply.
z:
6 wire 6v @ 2 amps (no nameplate on this motor, the seller said these specs were for unipolar. it is a Oriental Vexta model # PH299-02B.)
The same power supply.
Can I use a 69.8k 1/2 watt 1percent for the x & y and a 27.4k for the z?
Also I have a 4000uf 100vdc cap on hand...can I hook that to the PS output?
Also,also...should I pick up a 82v zenier? Do i need it?
i have the 470uf's for the PS connection to the drives...
Sorry for all the ??'s but I'm making a shopping list and would like to get it right the first time...
Thanks in advance...
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
Calculating current limiting resistors (I need serious help) Konstantin General Electronics Discussion 13 07-25-2005 05:10 PM
Current limiting resistor pyrojon General Electronics Discussion 8 04-19-2005 09:47 PM
Misc surplus controllers, need help Hobbiest General Electronics Discussion 7 03-19-2005 01:54 AM
amp set resistor Don C Gecko Drives 6 02-10-2005 03:41 PM
5vdc from paralell port, not enough??? thuffner3 General Electronics Discussion 8 11-23-2004 07:07 AM
