Old 03-06-2008, 08:02 PM
skankpile is on a distinguished road
more than 2000 steps per rotatin?
I'm not sure whats wrong...
I've got 1.8deg stepper and the G203V, but at 2000 pulse steps from a parallex microprocessor its not making a full rotation.
Do I have the motor wired wrong? Its an 8 wire and wired in series,but would this happen if something is reversed or incorrectly wired... I'm at a loss and this seems to be the only out that I can think of..
Old 03-06-2008, 08:18 PM
Gold Member
Mariss Freimanis is on a distinguished road
Here's what it could be:
1) You have a 0.9 degree motor (400 full steps / rev) instead of 1.8 degrees.
2) You think you are sending 2,000 steps but you actually aren't.
3) The G203V is missing some sent steps because of interface timing or logic level incompatibilities.
4) Excessive rate of accel/decel; excessively course ramp staircasing, etc.
How can you tell?
1) The motor moves smoothly and repeatability is perfect, just it's not the right distance. Door #1 or #2.
2) The error is random (poor repetition) or the motor sounds rough. Door #3 or #4.
Mariss
Old 03-06-2008, 09:42 PM
yep.. logic error..
Mariss.. you know of anybody using your grex with parallax stamp/propeller.. or is it mostly just mach3?
Old 03-07-2008, 12:42 AM
Gold Member
Ah.., no. We just manufacture hardware. I have really no idea with what is done with it after it ships.
Mariss
Taig Micro Mill 2000 steps per unit JV11 Linear and Rotary Motion 4 09-26-2006 07:13 AM
Taig MicroMill 2000 and Mach 2, Steps/Unit?? JV11 Mach Software (ArtSoft software) 2 09-25-2006 09:32 PM
2000 RPM new TL-1 xyzcnc Haas Mills 2 04-19-2006 10:10 AM
Full Steps -vs- Micro Steps DJB282000 General Electronics Discussion 10 12-28-2005 11:25 PM
