Hi everyone..I am running some big motors on my table that is still being built..1200oz/in from keling..The power source is 72 volts 20amps(keling)..so what gauge of wire should be used to wire up each of the 203v..also when it comes to the 3 wire leads from the BOB to the 203v driver,can I twist them to make a tighter cleaner wire job..I tryed taking the ends of the 3 wires and twisting them using a cordless drill..works great but is that the thing to do..maybe causing some sort of cross over problem??..Mike |
| I can't tell you want you should use.... I've only done one controller, I did use g203v's. This is what I used: 22g wire between bob and drive 18g wire between drive and motors 14g wire between power supply and drive (I had a hard time getting 14g into terminals) I'll use 16g or 18g if I decide to add a cap to the drive.
__________________ Walking is highly over-rated |
| Need some quick help RE gauge wire | Burn | Benchtop Machines | 13 | 06-12-2007 08:52 PM |
| Soldering 12 gauge copper wire | charper | Welding, Brazing, Soldering, Sealing | 9 | 03-24-2007 09:04 PM |
| Stepper wire gauge | stdly | Stepper Motors and Drives | 14 | 02-18-2006 12:18 AM |
| Wire Gauge | CapnC | General Electronics Discussion | 1 | 01-06-2005 05:45 AM |
| Wire Gauge | yorttroy | General Electronics Discussion | 4 | 06-30-2004 08:29 PM |
