Old 01-24-2008, 12:22 AM
Gold Member
Mariss Freimanis is on a distinguished road
Cheap drives?
I'm interested to know what your thoughts are if Geckodrive should
produce an inexpensive, board-level drive. Target specs are:
1) 3A per phase, 50VDC max. Discrete all n-channel MOSFETs.
2) 10 microsteps per step, CPLD design.
3) No midband resonance compensation, no morphing.
4) No trimpot crossover adjust.
5) Audibly silent design (not a chopper, same PWM as a G203V).
6) No plate, no can, no nice connectors. Just a board and header.
7) No opto-isolator.
8) No heatsinking needed. Everything is surface-mount.
9) No protection circuitry.
10) Target price: $29 single quantity.
This proposed drive would be a derivative of the G203V stripped of all expensive items and many features in order to fit it into a $0.99 CPLD. It would still be a dual all n-channel full-bridge design using 20A rated discrete MOSFETs. Not a fragile monolithic IC design.
The idea is to make a bottom-price yet quality and rugged step motor drive. The "bang for the buck" equation works out to:
3A times 50VDC divided by $29 equals 5.17 as the value number. Try this equation on other drives. The bigger the number, the better the value.
Mariss
Old 01-24-2008, 12:46 AM
epineh is on a distinguished road
For me the question isn't whether or not you should make them, the question is "Are they ready yet ?"
Russell.
Old 01-24-2008, 02:35 AM
jalessi's Avatar
jalessi is on a distinguished road
Are they shipping yet?
Old 01-24-2008, 04:40 AM
Greolt is on a distinguished road
Yeah I'll have three thanks.
How do these four specs compare to say the Xylotex?
I guess this is a considerable difference
"It would still be a dual all n-channel full-bridge design using 20A rated discrete MOSFETs. Not a fragile monolithic IC design."
Greg
Old 01-24-2008, 07:01 AM
kreutz is on a distinguished road
I think they are going to be welcomed. Go ahead!!
Kreutz.
Old 01-24-2008, 01:01 PM
CountZero is on a distinguished road
I think they will be a great success!
Just out of curiosity, which CPLD do you intend to use?
Old 01-24-2008, 01:19 PM
pminmo's Avatar
pminmo is on a distinguished road
I think you would sell a boatload..........
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 01-24-2008, 01:38 PM
xitian is on a distinguished road
Sorry to get a bit off the subject… but still within the new product arena….
I would love to see gecko come out with a “dumb” IO product to bridge the gap between your drive’s and the PC. I own a GREX and have been very happy with it even though it was probably overkill for my application. I was mostly looking for the extra IO and external pulse generation then its ability to control motion by itself. I would think there would be a decent market for a product like this.
Maybe something with:
- Let’s the PC do all the thinking like other BOB’s
- Ethernet (I love this about the grex) or USB connectivity
- Pulse generation?? (I think this might make interfacing software much more complex.)
- Opt isolated
- Lots of IO
- More easily integrated with mach3 / emc / etc.
- Charge pump
- Drives can plug directly onto the board to reduce wiring.
- Foolproof like the G203V
I guess the question would be if you all just want to keep manufacturing mainly drives and if there would be a way to reduce the amount of support a device like this might consume for Gecko.
On a side note I think there might be a market for a new low cost drive but I’ve been very happy with your current product offerings and think they are priced well.
Old 01-24-2008, 01:49 PM
Kelinginc is on a distinguished road
It is better to have protection circuitry
www.kelinginc.net
Old 01-24-2008, 02:12 PM
CoAMarcus's Avatar
CoAMarcus is on a distinguished road
Xitian, I understand where you are going, but we are drive manufacturers. We try to avoid producing anything but what we can do well, and that is motor controls. When we bring out a new product, the first thing we think about after designing is the support for the product. If we were to have a wide range of products, then we would have to also be proficient in our support of a wide range of products. This is something we may reconsider further down the road, but for right now we are going to just stick to motor controls.
CountZero: We intend to use the Xilinx CoolRunner II XC2C32A QFG32 CPLD. This will be small enough and cheap enough for us to mass produce the drives with. I am actually typing this while taking a break from programming the first revision of the drive, just to see how feasible it is to do. I feel fairly confident about this being doable, but I think slightly less so than my dad ;-).
-Marcus Freimanis
Old 01-24-2008, 02:38 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
This is a good Idea, any target price you have in mind.
I would think that you will want to be slightly higher than the 50v mark, because allot of people can have 48vdc easily.
You can call it the BG203 (Baby Gecko)
  #12   Ban this user!
Old 01-24-2008, 05:32 PM
microcarl is on a distinguished road
I think a reduced cost/functionality servo/stepper drive would be good. In my personal affairs, I run the G210 and G340 at 24VDC, at around 3 Amperes. This proposal fits within my requirements quite well. The price is also less demanding on the budget. I have a MAX-NC mill that I want to set up like my Sherline, running Mach3.
I currently don't use any of the features of the G210. I simply connect a break-out board to the PC and rely on the G210 optocouples for isolation. I could move the isolation to the break-out board.
Great idea! I'll take at least 3...
Tags
cheap drives, discount, dogs danglies, geckodrive, ghettodrive, opto-isolator
Interact Bosch servo drives for cheap!!!!!! Interact77 Bridgeport and Hardinge Mills 5 02-01-2010 05:29 PM
Avoid Teknic drives, they are cheap for a reason.... ckm Servo Motors and Drives 12 09-13-2009 09:58 AM
AMC drives ka67_72 Servo Motors and Drives 4 03-10-2007 06:38 AM
Can someone help me with these motor/drives, I think the drives are dodgy? Darc Stepper Motors and Drives 1 07-23-2005 06:31 PM
can you ID these drives SJ781 General Electronics Discussion 0 04-27-2004 09:16 PM
