| Am I right in my understanding that it doesn't matter if the supply voltage exceeds the maximum servo motor voltage, as long as it's under the 80V Gecko maximum as the G320/G340/G380 act like a switched power supply so the motor will only ever see the appropriate voltage level, as long as they are tuned correctly? I've got a 65V DC PSU but my motors are rated at 48V max |
| I don't think so. I think you need a power supply no larger than the servos rated voltage.
| Many drive manufacturers specify DC supply 110~120% of motor voltage, there is no direct line between PS and motor, there is a drive in between, higher than specified peak voltage perse on a motor does not damage it, unless allowed to overspeed, RPM is is relative to voltage, so as long as the drive controls both the average voltage and max current level, usually no harm is done. Here is an exellent article on PS, Drive and motor selection. http://electronicdesign.com/Articles...ArticleID=7635 Al.
| Is Gecko 320 tuning supply voltage dependant? | digits | Gecko Drives | 0 | 06-19-2007 06:59 AM |
| motor voltage | planescott | Stepper Motors and Drives | 2 | 12-28-2005 09:28 PM |
| Transformer voltage seems too high for Gecko | bgolash | General Electronics Discussion | 14 | 12-25-2004 10:35 AM |
| Gecko Voltage Question | ninewgt | Gecko Drives | 10 | 08-01-2004 01:31 PM |
| servo motor voltage? | tpworks | Gecko Drives | 2 | 04-17-2004 02:34 AM |
