Old 12-26-2007, 04:00 PM
skipper is on a distinguished road
G203V using Keling package/breakout board Help?
Hi All,
I purchased the Keling CNC 495 oz-in motor package minus the motor drives. I am using the Gecko G203v drives. The Keling package provides a C10 breakout board. I am confused on how to wire the G203v to this board. The breakout board input/out put shows 2-com-3 which I am assuming is for one axis. Should the 2 be connected to the Direction on G203v and com to the common of the G203v and 3 to the Step of the G203v. I cannot find any wiring diagrams that uses the C10 as the breakout board. Does any have any experiece with this that they can enlighten me? I am surprised that the G20v did not come with a actual wiring schematic. I am attaching info on the C10 bord. Actually the file was to large to download so here is the link.
http://www.kelinginc.net/c10.pdf
Thanks,
Rene
Old 12-26-2007, 09:08 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
This is a typical set up, Make sure you have the jumper set for common ground(jumper 1-2) Term 10 will be wired to com on the bob
STEP X Pin 2
DIR X Pin 3
STEP Y Pin 4
DIR Y Pin 5
STEP Z Pin 6
DIR Z Pin 7
Is breakout board essential if I got G203V? mealman Gecko Drives 2 09-20-2007 09:52 AM
Is necessary to use a breakout board? rolveram Stepper Motors and Drives 15 08-28-2007 10:28 AM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Breakout Board bkkpool General Electronics Discussion 2 07-28-2006 01:15 PM
Breakout board joecnc2006 General Electronics Discussion 3 06-29-2006 09:33 AM
