Old 11-13-2007, 09:57 AM
doesitfloat is on a distinguished road
Want to go faster
I have 201's installed running tubocnc
all works fine.
I get cutterpaths from Unigraphics
That all works fine.. Just slow
50 Min to do a small part.
Want to install G901,s
Do I need 1 for each conrtroller?
Is it as Simple as it Looks to go up to 10 times faster?
Old 11-13-2007, 10:12 AM
Bubba's Avatar
Bubba is on a distinguished road
doesitfloat,
I am not sure you will be able to go faster just by adding this board. A lot depends on your mechanical setup and how much power your steppers have! Also, have you maxed out just how fast you can go in the configuration. Possibly you have your max speeds set to low? Or can you change the feed rate in your g-code program?
I would look at the last thing first! If you are telling it to go slow in the g-code file, it will still go slow as you have to change your configuration for using the multiplyer board. Remember it you multiply steps by 10, you have to change your steps/unit by X/10 or it will move 10x as far as you command. Therefore, no speed change!
Art
Old 11-13-2007, 10:31 AM
OK let me specify where it is slow.
Rapid movement Manual control of axis---fast
Manual g-code if a circle----fast
G code from UG feedrate at 30ipm and 10 ipm same and slow.
The code I'm importing is primarly goto point x,y,z... Hundreds of lines of that.
That is where it is slow.
I have my accelerations set high( I think I'll check when I get home.)
**thinking and typing out loud** Maybe my accelerations need to be set much higher because I'm telling to do so many small steps it never accelerates to the feed rate.
Old 11-13-2007, 10:56 AM
Bubba's Avatar
OK, sounds like there is not a problem with the machine. You indicate it will move fast enough when doing fairly long moves. So possibly it is an acceleration factor or just plain the piece that you are working on. It sounds like the moves are short in nature? Not knowing what your working on, might it be possible to re-cam using a larger tool? It won't speed up the moves, but it will take more material per pass? Do a roughing pass with a "large" tool and then finish with a smaller tool to achieve the desired finish.
Art
Old 11-14-2007, 11:32 AM
Went back and adjusted my accelerations.
X and Y at 5000 and Z at 2000
This doubled my old settings.
Part machine time went from 49 min to 12 min.
My test part is a bullet looking tube 1/2 " diameter by 2" long
Old 11-14-2007, 12:21 PM
Bubba's Avatar
Sounds like you got it fixed. Good luck
Art
Girls have been faster learners - for 6 million years WallCrawler CNCzone Club House 26 07-20-2007 11:18 PM
Faster TM1? drewmeister Haas Mills 6 02-21-2007 10:27 AM
Which is Best - Deeper Plunge/Faster Feed bill south General Metalwork Discussion 7 01-10-2007 11:42 AM
Why is speed faster than I set monte55 Machines running Mach Software 1 11-04-2006 10:48 AM
Is the new server faster? CNCadmin Polls 31 03-13-2004 07:03 PM
