Old 10-06-2007, 06:20 PM
jhowelb is an unknown quantity at this point
G203V & Parker S83–135 combo??
OK, before I create a bunch of smoke, let me ask.
Will a match between Gecko G293V and Parker/Compumotor S83–135 be a harmonious marriage? Or will one assassinate the other?
In reading the S drive manual I found reference to 170 volts and knowing the the 203 is designed for 16 to 80 volts makes me a bit uncomfortable. Granted the drive is the source and the motor is the recipient but I would much rather have some knowledgeable reassurance before I turn on the power.
comments, anyone?
John
Old 10-07-2007, 12:02 PM
Don't be bashful, venture an opinion. I you have one!...........anybody???!!!
Old 10-07-2007, 02:38 PM
Big John T is on a distinguished road
Well you not supposed to be able to BBQ the 203V... From a google it looks like a round stepper. Do you have any specs like resistance and current? That will at least tell you what voltage to run it at... For $40 you can get a pretty good square stepper from Automation Direct that works nice with the 203V
John
Old 10-07-2007, 04:25 PM
Gold Member
Mariss Freimanis is on a distinguished road
Nothing will get BBQed except your expectations. A motor intended for 170VDC operation will be low current, high inductance and will have poor high-speed performance. Like Big John said; get a new motor.:-)
Mariss
Old 10-07-2007, 04:47 PM
Thanks everyone.
I already have a Keling KL23H286-20-8B on the shelf which will be a 25 oz/in increase over the Parker with its original drive.
This project is to replace a blown drive on the Z axis on my mill so it won't have to move far or fast. I will try the parker stepper first as I'm too lazy to relish making a new mount with hand tools and then turn a bushing for the belt drive.
At least now I can proceed without fearing the grief of losing another drive
For anyone interested I've attached the S drive manual in PDF.
The following quote it all I've been able th glean!
"The S Drive provides power to the motor by switching 170VDC (120VAC input) at 21 KHz (nominal). This has the potential to radiate or conduct electrical noise along the motor cable, through the motor, and into the frame to which the motor is attached. It can also be conducted out of the drive into the AC power line. Use the following steps to prevent problems caused by electrical noise generated by the S Drive"
Old 10-08-2007, 06:44 PM
Thanks again, one last note on the subject.
The Gecko turns the Parker flawlessly and if it's any slower I can't tell. But then my mill/drill is a slow ponderous beast in any case.
Happy days are here again!
Parker Metalworking tmechanic CNC Plasma and Waterjet Machines 4 10-16-2008 08:37 PM
parker quick couplings spider Moldmaking 4 08-31-2007 10:00 AM
Parker steppers Motors os22b need help nextspinster General Electronics Discussion 1 04-07-2007 08:42 AM
In Need of 9 wire diagram for Parker Steppers gone4pepsi Benchtop Machines 0 03-30-2007 10:08 AM
PARKER 6K2 or 6K4 Motion controller TUCSONCNC Post Processors for MC 0 02-02-2007 12:07 AM
