Old 10-05-2007, 09:41 AM
Big John T is on a distinguished road
G203V Steps?
I can't seem to tell from the manual what step input I need for the G203V. Do I send full steps to the drive or some micro step? I know that it morphs from micro stepping to full stepping but I don't have a clue as to what I need to send it from EMC2...
John
Old 10-05-2007, 09:56 AM
Gold Member
Mariss Freimanis is on a distinguished road
It's 2,000 step pulses per motor revolution. It makes no difference if you are moving at 1RPM (33.33 steps per second) or 6,000RPM (200,000 steps per second).
Mariss
Old 10-05-2007, 10:02 AM
Torchhead is on a distinguished road
You always calculate the steps per inch (number of steps you send per inch of movement) as X10 in the formula. Lets say your stepper motor is mounted and has a 3:1 belt reduction. We know most steppers are 200 stpes per rev. TO spin the motor on REV you need 2000 steps from the computer (200 * 10 microsteps). Then you have to calculate the external gearing (belt reduction, leadscrew pitch (or rack and pinion GAIN) to get the actual total in the software.
So to answer: You always use the X10 number with any Gecko stepper drive. The fact the drive itself switches the step currents ad higher speeds does not change what you put in....that would be a nightmare to setup (:-)
Tom Caudle
www.CandCNC.com
Old 10-05-2007, 10:05 AM
Thanks for the fast response Mariss, I'll save the phone call to you when I get into real trouble LOL...
Ok, the 203v is a 10 micro step drive like the 201 and 202...
You might tell the web person to add that info to the description similar to the
201 and 202.
John
Old 10-05-2007, 10:09 AM
Thanks for the info Tom
John
G203v Malfunction jhowelb Gecko Drives 3 08-09-2007 05:07 PM
G203V wiring dneisler Gecko Drives 4 07-13-2007 01:10 AM
G203V - HomeShopCNC ccsparky Gecko Drives 2 04-03-2007 07:35 PM
G203V question Eson Gecko Drives 2 03-04-2007 02:56 PM
Full Steps -vs- Micro Steps DJB282000 General Electronics Discussion 10 12-28-2005 11:25 PM
