Old 09-24-2007, 09:57 AM
Cruiser is on a distinguished road
I think i zapped a 320
Mariss I just purchased a Keling servo motor & 320 & had a misunderstanding about the motor wiring to the 320 as i understood that the blk went to grnd and the red & grn or brn (colorblind here) went to 320 & the motor bucked once & quit. motor is good in that hooking red and blk to power it spinns nicely but i only get fault lights from the poor little 320 that i zapped ! I'm truely sorry about that (my ignorance i guess) But yesterday i ordered a 340 to replace it and would like to get the little 320 patched up if i can. with the above description can you tell if it would be worthwhile to send back for evaluation/repair or should i just where it around my neck for a while, and ponder my deeds done ? There is still a chance it is something else, but i really don't think so ! I get the fault light on when i hand rotate motor which says the encoder circuit is good, and i get a fault light when i send pulses from mach. It just isn't sending power to motor.
Don
IH v-3 early model owner
Old 09-25-2007, 06:27 PM
bsharp's Avatar
bsharp is on a distinguished road
Have same problem with two G320's
Hey I also have the same problem but with two G320's. I haven't heard a peep from any one about this. I am thinking of dissecting one and see If I can fix it. "muahahahaa"
I will give it a few more days and see if I can get a rise out of someone. But if I indeed do it I will let you know how it went.
