Old 09-16-2007, 07:00 PM
hecirp is on a distinguished road
When to switch on motor voltage to G201
Apologies in advance if this is a dumb question. I have a campbell breakout board. I have installed a switch to turn on the 70v power supply, and a 2nd switch to turn on 110v to the board. Do I need a 3rd switch to turn on the 70v dc to the gecko 201 so that the 201 does not get a power spike from the condenser? I am using mach3. Thanks in advance for any advice,
Harvey Price
Old 09-17-2007, 04:36 AM
Coastcutting is on a distinguished road
I am not sure why you need so many switches - turning on the mains should power up all your system. I have a Bob Campbell breakout board and Geckos and have a single power switch, all works fine.
Old 09-17-2007, 04:44 AM
Gold Member
CRFultz is on a distinguished road
Harvey,
I use a contactor to switch dc voltage on and off.
The charge pump circuit from Bob Campells BOB controls a SSR which in turn energizes the contactor. Output 4 on the BOB will energize when you press the reset button in mach 3.
Your setup is ok the way it is but you should let the BOB control when DC voltage is applied to the 201's
Chuck
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
Old 09-17-2007, 09:38 AM
doanwannapickle is on a distinguished road
Originally Posted by CRFultz View Post
Harvey,
Chuck
Like Chuck said.
Walt
Old 09-17-2007, 07:56 PM
Thanks to all for the advice. Where would I get a "contactor" and what size should I get? Is that a 12 v solenoid switch?
Thanks again for taking the time to answer.
Harvey Price
Old 09-18-2007, 09:45 AM
I don't recall the exact items I used but the initial switching is use is a reed relay like something on this page: http://www.mouser.com/catalog/631/1504.pdf
The SSR I used is like figure A on this page: http://www.mouser.com/catalog/631/1506.pdf
The reed relay I had laying around and the SSR I picked up on eBay.
Cheers,
Walt
Old 09-18-2007, 08:34 PM
Thanks Walt,
I will go research that,
Harvey
Brushed DC motor voltage? bunalmis Servo Motors and Drives 2 11-09-2006 03:23 PM
5-phase stepper motor with g201 ahmed Gecko Drives 0 04-17-2006 11:13 AM
help g201 motor speed ahmed Gecko Drives 2 03-24-2006 03:41 PM
motor voltage planescott Stepper Motors and Drives 2 12-28-2005 09:28 PM
servo motor voltage? tpworks Gecko Drives 2 04-17-2004 02:34 AM
