Old 05-13-2004, 06:36 PM
Don C is on a distinguished road
Capacitors
I am upgrading to a 38VAC toroid transformer it will produce 53VDC want size capacitor should I Use. I'm running 1.7v 4.7 amp motors in full winding on gecko 201 drives.
Old 05-13-2004, 07:21 PM
Gold Member
Mariss Freimanis is on a distinguished road
You didn't say how many motors so I'll guess 3.
Set the drives to 2.4 amps each. This is what you need when running the motors full winding. Use 24K or 27K current set resistors (2.4A times 47,000 / ( 7A - 2.4A) = 24.5K current set resistor).
Each drive will never exceed 2/3 times 2.4 amps or 1.6 amps maximum, so 3 drives will require a 4.8 amp power supply.
Cap size (uF) = 4.8 amps times 80,000 / 53 volts = 7,245 uF. Use any value between that and 3 times as large (21,736 uF). For instance, 10,000 uF at 63V would be dandy.
Mariss
Old 05-13-2004, 07:36 PM
Thanks, My router has been running great with a 24VAC power supply but this should give it more top speed and power.
Thanks again
Don C
Old 05-17-2004, 12:39 PM
Want difference does a 7,245uf verses a 21,000uf cap. I got two 8,000 and will put them in parallel to make 16000uf if it will help performance.
Power Supply Capacitors? jevs General Electronics Discussion 12 03-31-2005 03:23 PM
Need Source for Cheap PS Filter Capacitors? Bird_E General Electronics Discussion 2 02-08-2005 01:29 PM
Electronic Component Explanation DragnsBane General Electronics Discussion 16 11-02-2004 10:38 AM
Bleed down resistors for capacitors garagefela General Electronics Discussion 12 07-17-2004 09:40 AM
Whats wrong with this freaking rectifier part II Noah General Electronics Discussion 19 07-08-2004 09:41 PM
