Old 08-22-2007, 01:01 AM
Ed Williams is on a distinguished road
Gecko 320 power supply
I have two 24 volt transformers and my servo's are 36v motors. Would I be better off putting them in series and filtering them. Which would put be in the 50volt range or just use one transformer. This is a small mill 24"x40" table.
Thanks Ed
Old 08-28-2007, 11:42 AM
Runner4404spd is on a distinguished road
run them in parallel. thats what i did. you end up with more voltage when they are paired up and a filter capacitor is used.
Old 08-30-2007, 11:56 AM
cjmerlincnc is on a distinguished road
Yep, As above. Running two 24v transformers in parallel will double your current capability. 24v AC once rectified and smoothed by a capacitor will raise your 24v to 33.6v or thereabouts, an ideal result for your motors.
What power supply for Gecko 203V Goose80 Gecko Drives 8 12-03-2009 08:01 PM
Help Gecko 210 Power Supply ahmed Gecko Drives 5 05-25-2006 04:37 AM
Power supply calculations to use with Gecko???? Apples General Electronics Discussion 2 08-16-2005 07:22 AM
Gecko power supply DEEDEE Gecko Drives 7 08-02-2005 09:56 AM
Gecko G201s and power supply rickkun Gecko Drives 1 04-21-2005 09:22 PM
